Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here |
06-30-2004, 08:33 | #1 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 60520 Status: Offline Thanks Meter: 0 | SMS Counter for SL45i First many thanks for coolLang for the patch and RizaPN for conversion to SL45i. Here's my question: Does the patch only count the messages sent by using the original write message function, or does it also count those one sent by Java midlets? How does it count? Because if it's just a call to a firmware procedure I could add this to my Java midlet. |
06-30-2004, 08:45 | #2 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | The outgoing SMS counter is trapping the "Message Sent" function. So, the counter will be increased if the "Message Sent" function is called. From my searching through the sl45v56 firmware, there is no other "Message Sent" function other than those two which are trapped by the patch. Means: if the SMS Send function in Java midlet also generate that "Message Sent" screen, then it will also counted. rizapn |
07-01-2004, 12:01 | #4 (permalink) | |
Member: 60520 Status: Offline Thanks Meter: 0 | Quote:
Hm, I have to test if there's a window when I enable the "allow SMS" function. If there's still no window, I would just have to call the counting procedure in SMSC patch. Or can somebody tell me if there's normally a "message sent" window when sent a message through Java midlet? | |
07-01-2004, 12:26 | #5 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | I did test sending SMS using MicroReader, and found that the "Sent: " counter is not increased. My phone has no "Disable Allow SMS" patch installed. rizapn |
07-02-2004, 09:16 | #7 (permalink) | |
Crazy Poster Join Date: Oct 2003 Location: Poland, Osno Age: 39
Member: 41290 Status: Offline Thanks Meter: 0 | Quote:
07-02-2004, 22:37 | #8 (permalink) |
Member: 60520 Status: Offline Thanks Meter: 0 | Yes, that's right. I didn't test vBartek's patch myself, but can think of this possiblity: He deleted the help menu and replaced it with "CB messages". Since in germany no one uses CB anymore, you could replace this with the additional SMS counter menu from RizaPN. Here's the right SMS menu shortcut patch: Edit: correct patch now in flash patches thread! Last edited by rc-flitzer; 07-03-2004 at 13:10. |
SMS Counter for Nokia 3125 | mann_s_love | Nokia CDMA | 0 | 04-25-2007 19:08 |
Special SMS for SL45i | sihs | x4x, x5x Flashpatching | 4 | 12-19-2004 08:44 |
Improved Security SMS for SL45i | naransula | Siemens-Benq Flash Patching | 3 | 12-14-2004 19:45 |
SCI SMS Counter Info - error 50000 SMS received? | cyperghost | Siemens-Benq Flash Patching | 28 | 09-01-2004 07:46 |
Change predefined SMS for SL45i | nguyenbangson | x1x to x45/x50 | 1 | 08-06-2003 01:59 |
