Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2002 Location: -[r0]- Age: 42
Member: 9891 Status: Offline Thanks: 0
| Incoming Call Display, Hidden Number, need help @Forum member: If you can easily try to receive any call with hidden number, I need your help: - Please call to your SL, but no need to answer it, reject is enough. - Using AT+CGSN patch, dump RAM address data at address 000C:1000 if you are using the old version of ICD, or 000F:0800 if you are using the latest ones. - Tell me the values, hope it can help me to solve the hidden number problem in the ICD patch. Thank you very much, rizapn |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2004 Location: Ankara, Turkey Age: 40
Member: 69110 Status: Offline Thanks: 0
| Dear Riza, Following the instructions in your post I have created 4 bin files using Advanced ATCGSN Debugger. There are two versions; (1) Aug 23, 2004 (v2) and (2) Aug 25, 2004 (v2.2). For each version I dumped the memory area (1) while call in progress and (2) after call is rejected in accordance with your instructions (for old version at address 000C:1000 and for new version at address 000F:0800). The rej suffix in the file names represents that they were the files created after rejecting call. I attached the zip file to this post but you should rename it from txt to zip. Thanks for your efforts, Naransula |
| | #4 (permalink) |
| @naransula and trustkill: thank's for the file. But, sorry, it was not the content of the RAM location which I need. What I need is RAM location 000C:1000 = 31000h (or 000F:0800 = 3C800h for the new ICD) with size minimum 20h (usually one AT+CGSN command will produce 80h, but mamaich version provide 100h). The content will be started with a text (in ASCII) a:\Images\xxxxxxx.bmp ... In case you are using Hyperterminal (or something similar) to dump the data, here are the possible command (from some version of AT+CGSN patch): at+cgsn:c,1000 => original AT+CGSN version at+cgsn.d.c.1000 => my unpublished version at+cgsn:d031000 => mamaich version rizapn |
| | #5 (permalink) |
| Thanks for the explanation. I think here is what you want: at+cgsn:f,800 61 3A 5C 49 6D 61 67 65 72 5C 34 38 32 31 36 36 35 2E 62 6D 70 00 FF FF FF FF FF FF FF FF FF 02 7F 26 01 00 5E 08 0F 00 00 00 00 00 00 00 28 00 00 00 65 00 00 00 26 00 00 00 01 00 01 00 00 00 00 00 60 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF 00 7F FC AE 80 90 04 48 28 92 BF FE BF C7 FF FF FF 3F EB EE 24 00 10 02 A5 2A FF 55 FF C7 FF FF FF 3F 7F |
| | #6 (permalink) |
| Thank's naransula. From that dump, the file need to be called is : A:\Images\4821665.bmp ... My question: - when do you dump the data? after receiving call from the hidden ones, or? - did you receive call from that (4821665) before? Thank's, rizapn |
| | #7 (permalink) |
| sorry, I just tested the procedure while there is a call from a known number. Here is the case when there is a call from a hidden one. There is no difference between the files created both during the call and after the call. FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF |
| | #8 (permalink) |
| Thank's, naransula. Really unexpected result by me ![]() Please test again, and dump RAM area 000C:2E90 ... 1. Please dump it when the call is in process but the "ID withheld" is not displayed yet 2. Please dump after that string is displayed ... Thank's, rizapn |
| | #9 (permalink) |
| at+cgsn:c,2E90 during call; 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 19 00 00 00 00 00 after call is rejected: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 19 00 00 00 00 00 |
| | #10 (permalink) |
| OK, we close to the conclusion ![]() But, please dump : - before the string "ID withheld" is displayed, and - after the string "ID withheld" is displayed Both are before the call is rejected. ps: - naransula: how if we discuss it through the YM? I saw that you also have YM ... |
| | #11 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2003 Location: GERMANY Age: 38
Member: 27745 Status: Offline Thanks: 0
| I´d like to test the newest Memory Viewer. What do I have to enter when I want to check the data above ? Sorry, I´m @office behind many,many Firewalls and without any atcgsn or hex-edit..... |
| | #12 (permalink) |
| Using memory Viewer: - in the main screen : press * * 1 5 * 2 0 4 8 * then RED button - goto Card-Explorer and run memViewer.bin - to go to the next RAM location press RightSoft, LeftSoft to the prev.location if you are using the old ICD, press * * 1 2 * 4 0 9 6 * 15 = 0F, 2048 = 0800 12 = 0C, 4096 = 1000 or use my latest Capturer (as a hyperterminal) ... download from the my Geocities! site, http://www.geocities.com/rizapn rizapn Last edited by rizapn; 08-26-2004 at 10:06. |
| | #14 (permalink) |
| ... OK, ICD Update ... Please apply this (only the correction part), and then test again with the hidden number ... Hope it is solving the problem ... 0x44567F: 06 0B rizapn |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Sigmatel fxd t33i , after first incoming call, no backlight off, plz help | nakshatra | Chinese Miracle & PinFinder | 11 | 06-03-2010 07:31 |
| LG U890 no out going and incoming call using X-sim please help | simpleboy | LG | 0 | 11-19-2008 04:07 |
| D520 Call Key Not Work Need Help | sof940 | Samsung Hardware Repair Area | 6 | 08-20-2008 15:16 |
| Call failed motorola E398 need help | patoandres007 | Motorola Hardware Repair Section | 1 | 04-22-2008 04:04 |
