Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens-Benq Flash Patching
Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here
Old 08-08-2004, 14:10   #1 (permalink)
Member: 60520
Log Reader midlet
Hello!
Many people wanted a small tool for managing or at least displaying the log file, created by the great call logging patch from RizaPN. In "Flash Patching" thread I said I will write this midlet. Many ideas were listed, I'll post them here again.
Now I'm proud to present the first 0.1 version of "Log Reader". It's a light version, it can only display the entries of the log file, but you don't have to copy the log file or anything else. Just leave it in misc folder.
The log file has to be named as "cdYYYYMM.log" or "sdYYYYMM.log".
Java midlet loads in a second, needs another second for loading the log file. Should be fast enough.
Ideas:
Somebody asked about a midlet for looking / managing the call record logfile. I can create one (more functional than just reading with MicroReader), but you'll have to wait to mid of August. What for functions do you wish? My ideas:
- sum of all minutes and seconds (calculated with 60/1, 10/10, 1/1, 30/30, 60/30 etc. you can setup every combination)
- sum of time for different calls (mobile or normal numbers)
- you can setup wich dialling code stands for mobile calls (and which net)
- setup which number is your international code (+xx)
- list groupwise calls, i.e. unanswered, incoming and outgoing calls, sorted by time.
Old 08-08-2004, 15:51   #2 (permalink)
trustkill's Avatar
Member: 27745
Great work, thank you !
Old 08-08-2004, 16:14   #3 (permalink)
Member: 70080
Read mm from date, its always 08
Old 08-08-2004, 18:23   #4 (permalink)
Member: 60520
I know... didn't have time to implement and test java.util.Calendar class. I'll upload corrected version as soon as possible with year and month checker (not that you input 63rd month of year 2341 *g*).
btw: Year is also always 2004.
Old 08-08-2004, 22:17   #5 (permalink)
abomin's Avatar
Member: 48199
Hi! Nice midlet, thank U!
"I have a dream": midlet "Call List", that run by pressing the green button. It shows the list of call records with an elements: icon incoming/outgoing/unanswered, icon home/work/mobile, number or name from addressbook, date, time. LSK - options, RSK - write SMS, green button - dial this number, right arrow - detailed info. In options - open or store record in adr.book, change/delete record etc.
If .jar file is not compressed, midlet starts very quickly.
Old 08-09-2004, 12:49   #6 (permalink)
Member: 70080
Calendar cal=Calendar.getInstance();
int Year = cal.YEAR
int Month = cal.MONTH
i don't know function aka IntToStr() in Delphi.
if use DateField("Year&Month", DateField.DATE);?
Old 08-09-2004, 13:12   #7 (permalink)
Member: 60520
Thanks for giving advices. I found the same way yesterday by searching the net, it's already included in 0.11 version. Unfortunately I can't upload the version at the moment, just wait until the evening (european evening *g*).
Just for fun: IntToString in Java would be the static method Integer.toString(int i). The other way round (string to integer) is Integer.parseInt(String s).
Old 08-10-2004, 14:36   #8 (permalink)
Member: 75596
would you plz give a possibility to choose a font-size? cause now it's a little bit big (for me)?
thanx for great work!!!!!!!!!!!!!!
Old 08-10-2004, 16:36   #9 (permalink)
Member: 60520
Here is version 0.11 with automatic date. No other improvements, I have no time to do it. But ideas from abomin are quite good, most of them are easy to realize.
@ka81: No, other fonts are not so easy to do. Then I would have to program my own text view procedure (like in MicroReader) - this way it's much easier und faster to write with predefined Java methods.
Download Log Reader 0.11: http://home.arcor.de/sagem-x-5/logreader0.11.rar
Old 08-10-2004, 18:37   #10 (permalink)
hrfonouni's Avatar
Member: 27936
@rc-flitzer
thanks alot for logreader v0.11.
I have a question. is it possible that midlet sums the call charges according the charge rate we set up in charge setting of phone for outgoing calls?
is it possible the program has flexibility to assign different charge setting in different times, for example in my country the charge rate from 8:00 am to 9:00 pm is more than 9:00 pm to 8:00am of next day.
Old 08-10-2004, 21:52   #11 (permalink)
Member: 60520
I wouldn't use the set up charge rate from phone menu, that's a bit unflexible. It's of course possible to setup own charge rates in midlet. I'll add this in further version. You can edit a text file on your PC with your charge rates, copy to MMC, and midlet will use this data for calculating. So everyone can input his/her own data.
Old 08-11-2004, 07:44   #12 (permalink)
Member: 65231
@rc-fitzer: midlet is quite good, and works like a charm. Thanks! One suggestion though. Could you make it possible (while viewing one item) to view next and previous item, only with up/down arrow. This would be great. Now, we have to exit viewing one item to see list of items and then select another one...
I hope you understand what I mean...
Old 08-11-2004, 16:45   #13 (permalink)
Member: 60520
Another good idea, it comes in my to-do-list. But as I said, not before this weekend...
Old 08-11-2004, 18:29   #14 (permalink)
Member: 44512
UP/LEFT - DOWN/RIGHT - to navigate between records is good idea
I think, better view You can set with this layout(need parse log record ',' separator)
..YYYY-MM-DD HH:MI
........Incoming............ <------- {enum Type}Incoming/Outgoing/U ..... etc
.......+XXXXXXXXXX..... <------- call number
............MM:SS.......... <------- duration
for SMS log the same
ps
Old 08-12-2004, 18:34   #15 (permalink)
Member: 70080
LogReader Modifed =) test version
7210 mail reader midlet & other questions mikk76 Nokia Multimedia 0 07-18-2003 09:21
DCT4 Log Readers With 3 Free Logs £80! CompleteFone Main Sales Section 1 06-27-2002 17:55
DCT4 Log Readers, Logs + Flashers New Low Prices! CompleteFone Main Sales Section 1 06-26-2002 13:38
sagem 3026 log reader patric Infineon C16X M51 & ARM7 M52 BASED 1 01-28-2002 14:11
want to by siemens log reader beginer x1x to x45/x50 0 10-07-2000 16:58
Page generated in 0.42836 seconds with 12 queries
