Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens-Benq Flash Patching
Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here
Old 03-30-2005, 19:41   #1 (permalink)
trustkill's Avatar
Member: 27745
OpenBFB for SL45v56: Question
Hi seklth, I installed the long awaited OpenBFB Patch (200290: 60 00),
and tried out SiemensDebugger: Doesnt work, program stops.
I tried SiemensScreenshot: Soemtimes it works, sometimes not. Buggy programmed tool ? (It works only once after a restart of phone) I use rizas capturer ist 100x easier to use...
Old 03-31-2005, 07:27   #2 (permalink)
naransula's Avatar
Member: 69110
@trustkill: this is what I have experienced with the really long awaited OpenBFB Patch
(1) in order to run SiemensScreenshot; the phone should be connected to the computer via cable (synchronisation station) and you should switch to Acid's AT+CGSN (not Mamaich).
(2) in order to run SiemensDebugger; the phone should be connected to the computer via IRDA (it did not work for me via cable) and again you should switch to Acid's AT+CGSN (not Mamaich).
additionally you should also properly set the connection speed (if you install the patch increasing connection speed then you should set the value to 115200).
Old 04-01-2005, 05:32   #3 (permalink)
Member: 79973
It works fine via cable(debugger). Turn phone off when you've pressed 'enter service mode' and turn on after. Phone will enter service mode. Then press 'restart' in debugger, and 'start service mode' again.
Old 04-01-2005, 05:43   #4 (permalink)
^NaT^'s Avatar
Member: 114558
Hi all.I have same problem's @trustkill.
I apply this patch.
;*** OpenBFB for SL45v56 ***
;tnx to Sinclair =)
200290: 60 00
but...SiemensScreenshot show 2 error message.
Try #0
Try #1
Try #2
switching to old phone mode.
Error getting mobile in BFB mode. Check Baudrate.
and
Unknow Display Typ: 0C add this value to INI File.
How to config with 2 error message.
please help me.
thank you very much.
Please, Help Me For 3 Questions COMMANDCOM Sony Ericsson 6 11-04-2003 17:53
Tones and pics for t300-question Abe Sony Ericsson 5 12-14-2002 02:33
Could you answer for my question? PLEASE zender VLSI, Conexant, Skyworks and Old Models 3 02-21-2002 15:18
Please help me for a question... GrAnD Hardware Equipments for GSM 2 12-04-2001 05:54
flash for T10 - question MP Old Ericsson Phones & Sony Phones 6 05-12-2000 07:38
Page generated in 0.22473 seconds with 11 queries
