patched SL45i v56 switches off during conversation I have a 6688 Flashed with SLIKv56 It works beautifully. I then add following patches: Show an icon home-office-mobile on incoming call - v3.vkp Record button shortcuts.vkp Name & Number.vkp Skip and Exit button for MP3Player.vkp MP3 -1 Indicators.vkp MP3 -2 Gfx.vkp CMB. Call Minutes Beep Modification v2.vkp Date as Mo,12 Apr.vkp Eliminate Keylocked message box when locking the keypad.vkp Auto Power On.vkp Add support of Kingmax v02 and v03 MMC.vkp All of them do not switch the phone off on their own. So is anyone able to tell me which one is clashing. As far as I can see, none of the vkp modify the same address range. Also CMB. Call Minutes Beep Modification v2.vkp does not work for me. Also some vkp's have addresses such as 0x####### Do I keep the 0x or do I delete it? I read in the forums that the 0x just stands for Hex code. Do you require any more info? |
well I use hmm.... 40 to 50 patches in my mobile and it don't crashes I don't use Show an icon home-office-mobile on incoming call - v3.vkp MP3 -1 Indicators.vkp MP3 -2 Gfx.vkp Auto Power On.vkp Add support of Kingmax v02 and v03 MMC.vkp I think it's possible that Show an icon home-office-mobile on incoming call - v3.vkp and Name & Number.vkp can collade. Try to remove the "Show icon" because I think it's useless if you see the number of the person who calls you ;) the 0x####### That's okay, it shows that this adress is an HEX adress ;) --------- Edit: Try to use the second version of Number&Name, the first contains some bugs. I had the same problems during writing SMS, then I used the patch of mamaich (the flash_edit.vkp) and the problem was solved as I activated: Try this fixes (I copied them out of mamaichs patch - hope he forgives my sins ;)) 241fe4: 8d24 CC00 241ff2: 9d20 cc00 242006: 9d19 cc00 24200c: 8d16 cc00 241f28: 9d1e cc00 241f44: 9d13 cc00 20C20A: ED07 CC00 22B9DA: 3d 0D 22D116: ED 0D 2B0A9E: 9BFE cc00 |
Thanks for the reply cypherghost I currently cut my patches down to the 4 below and the phone is working fine. 1. Record button shortcuts.vkp 2. Date as Mo,12 Apr.vkp 3. Show an icon home-office-mobile on incoming call - v3.vkp 4. Name & Number v2.vkp So it must be one of the others. I checked the address ranges of all and none write over same address!! So I guess it's just going to be a long slow process of elimination. Cypherghost In regards to patch of mamaich (the flash_edit.vkp) the section you are quoting is missing the last 3 lines. I have included the 3 missing lines below. Is there any reason you omitted them? 215e12: E64734B79BFE E0FCC4C09203 2DCA7F: 30 00 2b0bf4: 9bfe cc00 |
The first line of your psting contains a jump to an adress for java - sorry I missed to post that ;) It's no problem to use mamaichs whole patch, I commented the MP3 Playlist content, the MP3 time content, and the analog clock content, the rest may be usefull (Online Flash Patching, Direct Java Acess.......) I think you use that patch coz you patched the "Record of Incoming/Outgoing call" feature ;) No Problem. If you have any questions don't be afraid of asking ;) ----------------------- Edit: Never patch many patches together, you'll never find out, which one runs instable. But as a little tip, most patches of Riza don't collade together (and if V_Klay reports wrong data please don't ignore that - you can ignore if you really know what you do ;)) |
It can by a battery problem I think it could be on battery. I had the same problem. But it happend with nonpatched to me "the battery was few minutes after rechardchging", but the mp3 played more then 4 hours. :confused: |
No it's not the battery it's a damaged power amplifier in your case. My mobile also turned off sometimes caused by wrong battery contact ;) But the problem is solved Quote:
