Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here |
11-13-2004, 16:42 | #1 (permalink) |
Crazy Poster Join Date: Jun 2004 Location: Szczecin (Poland) Age: 41
Member: 68809 Status: Offline Thanks Meter: 0 | Read problems with Java applications I'm experiencing a strange and annoying problem with some Java applications when I am trying to read some files with them. For example logNavigator doesn't sometimes read logs, Spruce Notes - does the same with notes, and some other applications don't even start (as error occurs). Everything gets normal only after I restart the phone. Which patch is the cause? Can somebody help me? |
11-14-2004, 00:17 | #2 (permalink) |
Freak Poster Join Date: May 2004
Member: 65231 Status: Offline Thanks Meter: 0 | Search the forum, it was discussed before. You're not the only one, many people are annoyed with this. Too bad Riza can't complete his work on CDR patch, which is the cause, by the way. Disable CDR and all will work as normal. |
nokia n90 problem with java pls help! | joshuagutierrez | Nokia Base Band 5 ( BB-5 ) | 0 | 06-13-2006 17:26 |
Problem with Installation applications | boss_2005 | HTC & PDA WM( With Touchscreen) | 0 | 11-02-2005 14:11 |
problem with psiloc applications | cheema2005 | Nokia Multimedia | 0 | 05-05-2005 02:17 |
help with java application | cyrusthevirus41 | Nokia Multimedia | 0 | 04-09-2004 03:33 |
SL42 Problem with Java | Atlas100 | x1x to x45/x50 | 5 | 07-02-2002 06:28 |
