Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 07-22-2003, 08:55   #1 (permalink)
modrone's Avatar
Member: 34029
1000mAh akku for sl45i/6688i
Hi Everybody!
I heard that this high capacity akku doesn't work until I upload somethin' to the phone.
Can somebody give me aid in this question?
I also need information in charging styles. Do Li akku-s need a first time 16h charging? Do it need to totally dousing?
Old 07-27-2003, 02:51   #2 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Re: 1000mAh akku for sl45i/6688i
Originally posted by modrone
Hi Everybody!
1000 mAh works ok.
Every batt being new, must have their first time (check time with Siemens manual) charge.
Dousing? sorry didnīt get that...
Old 07-28-2003, 10:22   #3 (permalink)
modrone's Avatar
Member: 34029
Hello!
Sorry I'm Hungarian, can you write it a little bit clearer for me?
- 1000 mAh works ok.
Before the first time charge I have to decharge it with use?
Or avoid use and charge for ? (how many?) hours in on (?) or off (phone status) mode.
- Dousing? sorry didnīt get that...
means decharge, i think..
thanx
Old 07-28-2003, 11:37   #4 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Hello!
thanx
Sorry...
I mean every battery that you buy, you need to charge that first (obliged) time.
Yes, for a full battery performance u should decharge the battery and then charge it for the hours that siemens recommends.
Thanks
Old 07-30-2003, 11:48   #5 (permalink)
Member: 33336
Blk settings are erratic. Don't mess around with them unless you have to.
Blk settings will never work fine on another phone, even if it's the same model......
Old 07-31-2003, 00:21   #6 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Huh...?!?!? Whoīs talking about blk and changing battery values here?
Maybe u did some confusion with some other topic...
Old 07-31-2003, 12:59   #7 (permalink)
Member: 33336
Oh! My apologies! Sorry!
Old 07-31-2003, 21:57   #8 (permalink)
Peki's Avatar
Member: 35427
I got a noname 1000mAh akku too for my SL and its also weak just like the standard but its ok....it wasn`t such expensive like siemens 1000mAh.
We shouldn`t expect too much...
GREETZ
Old 08-01-2003, 00:42   #9 (permalink)
Peki's Avatar
Member: 35427
@ALL
I looked in my netmonitor and realized that my akku(1000mAh) after full charge is just on 700mAh.
Means that the akku is just bigger as the usual and delivers only the same quantity....
Check it out!
Old 08-01-2003, 10:49   #10 (permalink)
Member: 33336
Hey Peki, I was wondering if you could tell me how you enabled net monitor?
Old 08-02-2003, 13:41   #11 (permalink)
Member: 15689
I check my 1000 mAh battery, fully charged is 770 mAh and phone turn off with 700 mAh :-( I cannot find good blk file for it...
Old 08-03-2003, 20:52   #12 (permalink)
-V-O-Y-A-G-E-R-'s Avatar
Member: 25507
Anybody had a original 1000mAh battery? Any pics of it..i'd like to see how much bigger it is
Old 08-04-2003, 09:37   #13 (permalink)
Member: 22680
I have original Siemens 1000Mah. Using it 3 days already without charging. Seeking it's resource! Now it is only one position down from full state and voltage is 3.78. Being new, it was charged 3 days ago until indicator fills. Li-Ion batts does not need 16h charging, because they do NOT have memory-effect.
Old 08-06-2003, 11:01   #14 (permalink)
modrone's Avatar
Member: 34029
Hi Everyone!
What do you know about .blk-s?
How can I create one?
What programs needed?
Do you have a good .blk for the thin and tight (1000mAh)
battery-s?
If you have; Can U send me what you use?
Thanx
Modrone
Old 08-07-2003, 08:57   #15 (permalink)
Member: 33336
Do not mess with your phone.
Block file for 1000mAh aksi for sl45i modrone x1x to x45/x50 6 12-02-2003 10:12
PROBLEM-1000mAh battery for SL45i Witek x1x to x45/x50 2 06-28-2003 21:42
V55 for SL45i for real, not for SLCK(6688i) Drug_Store x1x to x45/x50 14 12-01-2002 22:56
Who can make me a Rep.-File for SL45i ??? Proggy x1x to x45/x50 1 01-15-2002 02:29
Search Firmware 43 for SL45i Please Help !!! sl45man x1x to x45/x50 0 11-02-2001 13:14
Page generated in 0.36030 seconds with 11 queries
