x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-15-2002, 10:47 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: gujarat india
Member: 4600 Status: Offline Thanks Meter: 79 | A36 V23 problem Now How to full flash the phone and upload workign eeprom ? where can i gen flasher and eeprom uploader with files ? |
06-24-2002, 15:44 | #7 (permalink) |
Junior Member Join Date: Feb 2002 Location: philippines
Member: 9587 Status: Offline Thanks Meter: 0 | a36v25 problem Hi! i am new with unlocking siemens, i got an old soft i tried to upgrade actually downgrade to version 13 to unlock using skeptik soft. now my fon is dead..pls help what soft should i use to read the log? thanks |
06-24-2002, 22:37 | #8 (permalink) | |
No Life Poster Join Date: Mar 2001 Location: Leiria, PT & *******, CN
Member: 3756 Status: Offline Thanks Meter: 5 | Re: a36v25 problem Quote:
Well, first thing you should know is that u can't make such big downgrades like 25 => 13 the phone will die.... I guess you already know that by now... Now i sugest you to flash phone with version 20 or above (personally, i already did 25 => 20 without any problem). Then you can use log to unlock your phone. You can get a logger from here To read a log is pretty simple... Choose the desired phone model and just hit "Read Phone" (phone must be off) and when "Scanning" is displayed just hit power on for a short time. Pretty simple. Then, to calculate your log file you can use the free calculator already available on the web... or post the log in the "Log Request" area... Bye and good luck. | |
06-25-2002, 11:17 | #12 (permalink) | |
Member: 3756 Status: Offline Thanks Meter: 5 | Quote:
user: mobile pass: elibom Good luck. Bye. | |
A36 v23 | orepi | x1x to x45/x50 | 6 | 09-03-2001 22:07 |
A36 v23 | Havi | x1x to x45/x50 | 2 | 08-30-2001 21:34 |
TESTED sucesfully siemens A36 V23 with Swand's sw | nicanorr | x1x to x45/x50 | 8 | 08-22-2001 00:43 |
A36 v23 - Wrong Soft | Dubpoison | x1x to x45/x50 | 5 | 07-31-2001 22:54 |
Wrong Software with A36 v23 | khansa | x1x to x45/x50 | 1 | 07-26-2001 12:45 |
