A50 = c45 !!! Too many peple talking too many nonsenses!!!!!!!! A 50 = C 45 There are 2 differents Regards |
yes,you maybe are one of them... and little secret... bullshirt |
c45=a50 not the same hardware is same but soft is very difirent +flash chip is difirent |
yes only flash adres is same with c45 20000 to 40000 |
is it using same cpu as c45 or same as m50 ? , i still don't have any chance to see the phone till today |
There are on same platform, known as K45. CPU can be driven in different boot modes. (For more detailed info read Infineon's documents for PMB6xxx ASIC.) And in C45 CPU uses it's internal boot code. In A50 CPU uses external boot code, located in FLASH (Boot core). WBR Assen |
Assen , you are 99% wright - K45 project is S45&Me45!:cool: |
M50, MT50 and A50 too. Believe me, I have some service papers, level 2.5e. |
you are not alone :) Quote:
A50 = C45 Hello, guys. I'm sure for my words. AssenBG, How you repair A50 from wrong software? How? You cleàn one resistor and remove one resistor. In finish you flash A50 whit C45 flash v17 or high /couese it is whit Li-ion batt support/ and map it. Very simple. I know where are resistors on the board. Regards |
He-he 8-) WBR Crew |
Well, Everybody says "I know these resistors, I can make some maps ". Well guys. Tell me just one word what can You do if inside phone power management IC is not a DIALOG and it is ST? Phone's backlights begin to blink, and most important, phone can not hold the network (very bad news). Nothing at this time, I'm sure, nothing. Just one more well damaged phone for spare parts. |
Yes ! pc.net is right I'm tested 100% work man, solutions : 1. remove one resistor (nearly pin A1 CPU ) 2. clean one resistor (nearly pin P6 CPU ) |
pc.net hi pc can u please send me a pic on where to locate these resistors at |
