x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-10-2002, 22:37 | #1 (permalink) |
Junior Member Join Date: May 2002 Location: UAE Age: 52
Member: 12404 Status: Offline Thanks Meter: 0 | All 3/4 siemens service software Any response appreciated Thanx is advance Regards Girish |
06-11-2002, 00:13 | #4 (permalink) |
Member: 12404 Status: Offline Thanks Meter: 0 | no .flx file Thanx a lot for the response Keni & Roniri... But Roniri, I tried to use flashing and IMEI together but it gives the error message "No Flash Data loaded. FLX buffer empty" ... so I have to load a .flx file first.. unfortunately I don't have it .. do you know how I can get one? Once again thanx for responding.. Regards Girish |
06-11-2002, 03:13 | #5 (permalink) |
Member: 12404 Status: Offline Thanks Meter: 0 | Hello Keni Kenny Exactly what you told happened ... it erased all my EEPROM...I tried running the .flx files from this software it was showing error messages "No Compatible Hardware found"... it erased all my EEPROM and halted with a message "Waiting for CalcThread to exit" ... now when I try to switch on my phone, nothing is happening at all... before it used to beep once without display or light.... what is parallel dongle or crack version which you mentioned?? what can I do at this stage to bring back my mobile to life??? Thanx in advance ...any response appreciated... Regards Girish |
06-11-2002, 03:23 | #6 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | Do you have box for All3/4 software?If you have i can send you flashfile or you can download from bontek site. If you have only the software without dongle,than i can't help you.Regards Roniri |
06-11-2002, 03:58 | #9 (permalink) |
Member: 12404 Status: Offline Thanks Meter: 0 | Use original flasher first to write correct firmware while trying to read with sme45_r.exe it says "Model "yyyyyyyy" not supported or flash data destroyed. Use original flasher first to write correct firmware" ... its not giving a .ldb file... Is there any solution??/ thanx regards Girish |
06-11-2002, 04:12 | #10 (permalink) |
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | Try to flash first! You can download it from http://siemensx35.prv.pl ,than try to read log. |
06-11-2002, 04:24 | #11 (permalink) |
Member: 12404 Status: Offline Thanks Meter: 0 | not sensing that update tool doesn't sense the mobile... looks like its because its only an update tool and not the original flash... or is it because i'm not using an auto-ignition cable??? thanx regards Girish |
06-13-2002, 15:54 | #12 (permalink) |
Freak Poster Join Date: May 2001 Location: Indian Ocean Age: 54
Member: 4765 Status: Offline Thanks Meter: 0 | not working without dongle, this sw f*-ck your phone. i killed my phone but i could revive it after ... now i am wondering even there is a sw to unlock c45 without using map file. |
06-13-2002, 16:36 | #13 (permalink) |
Member: 12404 Status: Offline Thanks Meter: 0 | but how??? Hi there rayback... how'd you revive your phone after being f****d up by that software???.. I'm struggling without any result.. tried all ways I could think of and whatever ways I got from the forum.. please help if u know what to do!!!! thanx in advance... Regrads Girish |
06-13-2002, 16:58 | #14 (permalink) |
Member: 4765 Status: Offline Thanks Meter: 0 | Use search functions Read old topics HFP said "by searching inside old topics, you will able to repair damage eeprom". Use search function and put "repair" and "eeprom" in search field, you will have 6 posts talking about that in x45x section. |
All 3/4 Siemens Service Software v2.1.0 | It's Me 2 | Siemens-Benq RingTones and WallPapers | 6 | 07-24-2003 17:47 |
All 3/4 Siemens Service Software v 2.0.9 ??? | masterross | x1x to x45/x50 | 6 | 08-28-2002 09:53 |
FREE Update for All 3/4 Siemens Series Software and LOG Calculator - v2.0.7 / 1.3 ! | bontek | x1x to x45/x50 | 0 | 04-17-2002 04:34 |
All 3/4 Series Service Software - Software with Flashing / Uploading Languages !!! | bontek | Main Sales Section | 3 | 01-25-2002 00:24 |
All 3/4 Series Service Software 2.0.3 Released - FREE UPGRADE For Our Customers !!! | bontek | Main Sales Section | 0 | 11-27-2001 02:43 |
