x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
05-31-2003, 20:27 | #4 (permalink) | |
Junior Member Join Date: May 2003 Location: riyadh Age: 49
Member: 29385 Status: Offline Thanks Meter: 0 | Quote:
what do you mean my friend by the .exe file with the 2 skip buttons and thank you | |
05-31-2003, 22:31 | #6 (permalink) |
Freak Poster Join Date: May 2003 Location: Tehran Age: 52
Member: 27936 Status: Offline Thanks Meter: 0 | Try fullflash your phone with V-Klay , from address 0x000000 and size 0x5f0000 and offset 0x000000. find the firmware 5601 from this link: http://www.gsm-multifund.de/index2.html in siemens section go to update and download fw5601 or directly download via this link: http://www.gsm-multifund.com/update/sl45i_SW_56.zip you can find V_klay file from here:http://www.is.svitonline.com/valeravi/ Press "open file...” then select your full-flash file. - In the section "memory of the phone" set from address=0x000000, size=0x5f0000. - In the section "Buffer of program" set Offset=0x000000 -Press "Write memory" - When you see "Connecting......" Turn off the phone, THEN CONNECT IT (INSERT) TO the data cable. - wait until all data will be written Last edited by hrfonouni; 06-01-2003 at 08:40. |
06-05-2003, 08:32 | #9 (permalink) | |
Member: 28246 Status: Offline Thanks Meter: 0 | Quote:
06-05-2003, 12:28 | #11 (permalink) |
Member: 27936 Status: Offline Thanks Meter: 0 | Have you done all I said above? maybe you missed an option? and maybe you damaged your eeprom then you must fullflash your phone and then write eeprom manually. |
w900 dead after flashing...plzzzzz help | mplus | Sony Ericsson Media, RingTones, Games | 1 | 07-05-2006 08:33 |
plzzz plzzzzz help me | ulhassanuk | CAR Electronics | 0 | 06-01-2006 17:00 |
6600 glass ic i.e at extree left to keypad connector broke plzzzzz help me to turn o | anantnivas | Nokia Hardware & Hardware Repair | 1 | 04-15-2006 22:41 |
plzzzzz help in k750i | scorpion_king | Cruiser Suite | 1 | 04-08-2006 16:05 |
Plzzzzz help me about slovoed keygen | tarikhmami | Nokia Multimedia | 0 | 05-08-2005 18:11 |
