Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
| | #1 (permalink) |
| Junior Member Join Date: Jul 2003 Age: 34
Member: 35859 Status: Offline Thanks: 0
| Hi~~ when I use Ksid2.0 to read from my dead C45 2118,it displays: COMM_LoadBoots : selected phone family is 2 TTY_OpenCOMPort : opening COM1 COMM_IsBootRunning : bootcode does not seem to be running COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is powered on COMM_SendBoot : boot file is not accepted is the bootcode bad?then how can I do? |
| | #2 (permalink) |
| Junior Member Join Date: May 2003
Member: 28246 Status: Offline Thanks: 0
| when the message COMM_LoadBoots : Waiting to power on the phone ... is up, try to press the power button several time but not until poweron. If confuse, try to search button in this forum |
| | #3 (permalink) |
| Thaks for everybody~!!!the voltage is too lower~!! I have made my phone work now~!!!!! I used bellow method: 1:siemens all 3/4 2.1.0 cracked to load a C45 flx file,check write flash,write imei(make eep),then press init phone. 2:when 1st step done,use ksie2 full read log. if you select C45 or 2118,it doesn't work and report boot file is not accepted.here you can select Sl45 to read log from phone and save the file.then you should modify the log file hone model:Sl45=>C45,Desired IMEI:----=>Owner IMEI,then save the file.3:make map click the menu and select Create unclock Map from log,follow it select the log file last you modified.Oh sorry~~here you should change the phone model to C45. 4:wirte Map click the unclock menu and select load Map to phone.select the Map file last you made,and update to phone. 5:when if finish,you can save your phone now~!!!!! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| a52: bootcode does not seem to be running | teccim | E-Gold Based Phones | 19 | 06-28-2005 12:57 |
| mc60 bootcode does not seem to be running | lazioroma | E-Gold Based Phones | 1 | 05-20-2005 12:28 |
| M55 - bootcode not accepted. !!help please | lastdon | E-Gold Based Phones | 4 | 06-28-2004 16:50 |
| How to repair TSM400 Bootcode? | Uvedovle | HTC & PDA WM( With Touchscreen) | 0 | 05-08-2004 04:22 |
| Does bootcode lost~? | tontsin | Siemens Hardware Repair Area | 2 | 08-01-2003 06:58 |
