Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 12-06-2002, 17:14   #1 (permalink)
Member: 8446
Question C25/C28 PhoneID calculation
Does anybody know how to get phone id from dead C25 v61?
I found out that the algorithm for encryption of the IMEI is very similar to the one used in x35 series.
There are some differences of course, for example eelite block 1 is used instead of eelite block 76 together with block 5009 to encrypt the IMEI, but my overall impression is that it is pretty the same algo.
The seeds used in calculation are 79 91 73 FD 15 5F B1 95 and the calculation itself is exactly as in x35 series (everybody that have read the sources from Maxim should know what I'm talking about :-).
The problem is how to get the phone id from the phone?
It has different boot modes and boots in service mode, but BFB command 05 23 doesn't work :-(
Any ideas ?
Old 12-08-2002, 02:47   #2 (permalink)
Member: 6877
You probably have to use your own bootloader...
Some bootcode and PhoneID reading related stuff can be requested via my e-mail...
Old 12-09-2002, 16:48   #3 (permalink)
Member: 8446
Smile
I was right about the algo - it is really the same, just seeds are different :-)
I decoded the IMEI from the bin file floating around (c28 v61 good flash.bin) for example and the result is 4492484121627203 :-)
BTW: The algo for encoding block 5008 also seems to be the same as in x35 series as well.
@Sergey: Did you receive my private email?
Old 12-11-2002, 13:53   #4 (permalink)
Member: 8446
Smile C28 v.61 repaired :-)
After several days of hard work (disassembling the firmware) I managed to repair and unlock C28 v61 :-)
And used the phone itself to calculate the security blocks and unlock itself !!!
Finally I can return this phone to its owner totally repaired and unlocked :-)))
Regards to all!
Old 01-02-2003, 15:12   #5 (permalink)
Member: 11208
Hi.
Which software or tool you used for disassembling?
Thanks
Old 02-10-2004, 17:05   #6 (permalink)
Administrator
Winner58's Avatar
Member: 5
moved from GSM Programming
C25/C28 repair and unlock solution wazl x1x to x45/x50 21 06-12-2001 23:32
C25/C28 v61 repair. qido x1x to x45/x50 45 04-25-2001 19:01
i have unlock for c25/c28/s25 all vir. iceman1 x1x to x45/x50 12 04-06-2001 22:28
search link-Siemens C25/C28 Ver.61 Service Software Ver. 2.5 Baza GSM Mobile Links 2 04-05-2001 20:04
andromeda C25/C28 Ver.61 S-Software Ver. 2.5 Baza x1x to x45/x50 5 03-27-2001 23:29
Page generated in 0.25189 seconds with 11 queries
