x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
08-28-2001, 11:57 | #1 (permalink) |
Junior Member Join Date: Aug 2001 Location: Hungary
Member: 5684 Status: Offline Thanks Meter: 0 | From C25 v61 Dead ----> C25 v61 Wrong SW If You've killed your C25 v61 (No display at PowerOn), your phone can be work again, but with Wrong Software on display. Do this: with Siemens Tool v5.20 by Koci select Upload Flash, than select Phone Type C25 v61 & Full Flash Image File (use the flash for C25 Total Flasher 'C25_61 Good Flash.c2r' (available in many links), rename to *.c2i. Flash it, then phone will power on, but still not live. now flash it with original Siemens Flasher C25_6108.exe. The Phone will power on, with 'Wrong Software' |
08-28-2001, 19:02 | #2 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Austria
Member: 2832 Status: Offline Thanks Meter: 0 | Where can I get Siemens Tool v5.20 by Koci?<br />Could you send me this program? THX<br />Cyberdog [quote]Originally posted by VirtuaTech:<br /><strong>Hi, If You've killed your C25 v61 (No display at PowerOn), your phone can be work again, but with Wrong Software on display. Do this: with Siemens Tool v5.20 by Koci select Upload Flash, than select Phone Type C25 v61 & Full Flash Image File (use the flash for C25 Total Flasher 'C25_61 Good Flash.c2r' (available in many links), rename to *.c2i. Flash it, then phone will power on, but still not live. now flash it with original Siemens Flasher C25_6108.exe. The Phone will power on, with 'Wrong Software'</strong><hr></blockquote> |
08-30-2001, 08:19 | #5 (permalink) |
Junior Member Join Date: Apr 2001 Location: Macedonia
Member: 4284 Status: Offline Thanks Meter: 0 | Yeah, this is the right question: HOW REMOVE "WRONG SOFT" ON C25v61 when the Bartek 1.92 don't work on them. I think that NOBODY is not enought smart to resolve this problem. I try many solution but I give up.<br />Best regards... |
Dead C25 v61 after unlock | Defender | x1x to x45/x50 | 0 | 01-28-2002 12:19 |
dead c25 v61 | nedkokp | x1x to x45/x50 | 8 | 06-26-2001 23:44 |
Dead c25 v61 | cajt | x1x to x45/x50 | 4 | 06-19-2001 19:05 |
I got a Dead C25 V61 and a Working One with Same Ver. Can I Solve The Dead One ? | AboAli | x1x to x45/x50 | 0 | 04-24-2001 13:32 |
I work to make solution to repair dead c25 v61 | zdob | x1x to x45/x50 | 0 | 03-11-2001 14:39 |
