x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
05-20-2002, 03:08 | #2 (permalink) |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | HOw your mobile become Dead. and please explain your Problem in Detail. And also try to read old posts will help u, Best Regards, WaHaB |
05-21-2002, 04:15 | #3 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Portugal Age: 37
Member: 6080 Status: Offline Thanks Meter: 4 | martek The phone was killed by martek When I go to flashe the phone I can't because he doesn't (martek, Ziemens 1.22, ****** flasher, swup) erase the flash that is on the phone so I can't use Landy's method Regards |
05-23-2002, 04:52 | #5 (permalink) |
Junior Member Join Date: Jan 2001 Location: Deutschland
Member: 3163 Status: Offline Thanks Meter: 0 | In last 2 houres I becom my phon alive. My phon is dead.I use the swup 193 ,end when the erase it's finish I disconect the phone.Then I use the same swup to flash my phone to 1804 "when not automatic then press j for update when the qustion com".After this use zee 1.22 CEErepair end the phone it's alive.You must use the imei chenger for the corect imei end then you heve your phone unlocked end whit corect imei. |
E1 Totaly Dead.. :( :( Not enter Boot Mode.. | LoveLess | Motorola P2k | 9 | 12-03-2007 14:23 |
E1 Totaly Dead.. :( :( Not enter Boot Mode.. | LoveLess | Motorola Hardware Repair | 1 | 12-01-2007 10:17 |
Solution for C35 dead after full falshing? | hiall | x1x to x45/x50 | 8 | 07-20-2001 13:21 |
C35 Dead after flashing MARTECH ??? Any solution working 100% | Raul | x1x to x45/x50 | 1 | 04-23-2001 20:29 |
C35 dead after upgrade an downgrade | the_viper | x1x to x45/x50 | 6 | 03-24-2001 11:49 |
