x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
09-17-2002, 16:25 | #1 (permalink) |
Insane Poster Join Date: Oct 2000 Location: drachten/frl/holland
Member: 2244 Status: Offline Thanks Meter: 0 | c45 blank screen i have here a c45 who came in dead only brrrrrr sound when i first tried the unlock proggie prog says : eeprom damaged / no imei i flashed with new version (flash and eeprom with all34) calculated map phone is working good i can receive calls and make calls only nothing on screen tried new display : no result does anyone has a idea ? |
09-17-2002, 17:06 | #2 (permalink) |
Freak Poster Join Date: Jul 2002 Location: PA Age: 45
Member: 13453 Status: Offline Thanks Meter: 3 | try this sw siemens contrast tool plug on ur mobile and run this software... sometimes u need to repeat this a few times when the proggie says no ping reply from the mobile..... if this don't work then must be hardware problem hope this will help |
09-17-2002, 17:13 | #3 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Holland Age: 61
Member: 11291 Status: Offline Thanks Meter: 0 | Don`t worry there is nothing real wrong! You need to download eepromsolution from yahoo groops. Edit *.lc file to your phones id number then load lc in phone write map and it will be alieve again! wbr Rossifan |
09-17-2002, 17:28 | #4 (permalink) |
No Life Poster Join Date: Apr 2002 Location: South Spain Age: 41
Member: 10905 Status: Offline Thanks Meter: 109 | Hey man! Dont forget to have a look inside. Sometimes, the display doesn´t connect very well. Try to move the contacts or replace the display. Good luck!! |
09-17-2002, 19:59 | #5 (permalink) |
Freak Poster Join Date: Oct 2001
Member: 7011 Status: Offline Thanks Meter: 0 | you can find e2p on www.aggty******.com |
07-26-2003, 23:44 | #7 (permalink) |
Junior Member Join Date: Jul 2003 Location: pakistan
Member: 35625 Status: Offline Thanks Meter: 0 | Hello guys!! i had the same problem (after a long time of your posts) and you know what for me Uvedovle's sensible advice worked. i just pressed it a bit and the display was on again. what hapened was that it was wacked by a squash ball and i'm lucky that no real damage was done. Thanks. Shah |
kg195 blank screen no light in screen and keypad help me | shani72 | LG Hardware Repair | 0 | 09-26-2009 07:11 |
X500! W/O card screen ok, But With card Blank screen?????? | ReyTech | Infinity-Box | 7 | 07-23-2005 08:35 |
C45 blank display ? | -=ELF=- | Siemens Hardware Repair Area | 10 | 07-26-2003 23:48 |
c45 blank display strange problem | thecult | Nokia Hardware & Hardware Repair | 2 | 12-16-2002 14:33 |
C45 blank screen | Freeman | x1x to x45/x50 | 17 | 08-19-2002 00:26 |
