x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
05-18-2002, 01:54 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | Boot sequence using Ziemens122 When i used Martech. it stop at 5% at progress bar (Erasing progress) Using Swup, cant be connected using EGold PLS Help..... Hardware Problem ??? |
05-18-2002, 06:07 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Glasgow, Scotland
Member: 4690 Status: Offline Thanks Meter: 1 | I have had this type of problem before - a few times while playing about! Check out http://personal.telefonica.terra.es/...ndy/repair.htm TheLandy's page has a kickass "recovery" tut - If it doesn't work first time try again, and if no luck - slightly alter your method and it should work! Works for me if my problem is slightly "varied" |
Boot sequence failed | Magoo2 | x1x to x45/x50 | 22 | 03-02-2004 22:46 |
c25 v61 boot sequence failed, strange problem | Unlockie | x1x to x45/x50 | 3 | 09-01-2001 16:59 |
C25 boot sequence failed | Unlockie | x1x to x45/x50 | 1 | 07-17-2001 08:46 |
Boot sequence failed v61 | ]-[erbie | x1x to x45/x50 | 9 | 06-14-2001 04:26 |
Can't Use TotalFlasher on C25 becaus Executing Boot Sequence | UnlockHeaven | x1x to x45/x50 | 1 | 05-31-2001 11:04 |
