x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
07-08-2004, 11:12 | #1 (permalink) |
Junior Member Join Date: Jul 2004
Member: 72159 Status: Offline Thanks Meter: 0 | C45 -> Unblocking -> Dead -> ??? I have a C45 and tried to unlock it some days ago with some #*?%§"!-software... Now I have a phone that does not start anymore, instead it sounds a low pitched beep if you press the ON-button and that's all. I tried to flash the phone, first using an original siemens cable and after recognizing my error with a modified siemens cable (external +5V power supply to pin 1 & 4) and tried again - without success. Attempts to charge the phone are accopanied by an even lower beep. Any hints you can give me are most welcome. Thanks, grazer |
07-08-2004, 11:18 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Lazarevac,SRBIJA Age: 48
Member: 4772 Status: Offline Thanks Meter: 556 | use freia10 software to full flash your phone and after that use option unlock with using orginal imei.Use standard siemens cable or solution by bruce. regards |
07-08-2004, 14:30 | #3 (permalink) |
Member: 72159 Status: Offline Thanks Meter: 0 | All the software I tried, is not able to make a connection to the phone. If you press the red button shortly, nothing happens, if you press it for 1 sec. you will hear that low beep and nothing more. Any hints regarding the cable? Is the supply voltage of +5 needed? Thanks, grazer |
07-08-2004, 23:20 | #6 (permalink) |
Member: 72159 Status: Offline Thanks Meter: 0 | Do you need a 100% charged battery to flash the phone or does it also work with say 85% capacity? Can you also tell me if the behaviour of the phone is normal for an error in the flash memory (1 beep and nothing more if you trie to switch it on)? Bye, grazer |
Need help ==> Unblock Sony T303 | FrenchLolita | Phone Unlocking Codes & Maps | 9 | 07-29-2009 10:48 |
Need help ==> Unblock Sony T303 | FrenchLolita | Sony Ericsson | 1 | 07-15-2009 06:06 |
6280 v3.81 --> dead --> v6.10. Finally worked! | langnese | Nokia Base Band 5 ( BB-5 ) | 9 | 05-27-2007 14:42 |
R210s dead --> burned smd | Blu3fish | VLSI, Conexant, Skyworks and Old Models | 2 | 06-25-2003 08:11 |
