x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
03-05-2003, 21:13 | #1 (permalink) |
Junior Member Join Date: May 2002
Member: 12214 Status: Offline Thanks Meter: 0 | Dead SLik.. Unknown flash type. Pls Help Subj is Dead Slik, Unisiemens work ok, but write "Flash One ID: 0002, Type: 0000; Flash Two ID: 6CD4, Type: 0000 " Why Type 0000???? I don`t understand... When I try to use other software it say me something near " Flash not supported" Siemens unlock write "COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is powered on COMM_IsBootRunning : unknown flash id 0002" ... Winswup write "Unknown Flashcode B990" .. I try to use LC files but when I try to upload "corrected" LC file, get message " Unsupported flash configuration Flash HC=41B2B4" Pls help!... May be any have some idea? |
03-05-2003, 23:01 | #3 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Latvia, Riga Age: 46
Member: 20879 Status: Offline Thanks Meter: 0 | It happends with some experiments.... Aspecialy, when flashing phone with winswup, and take mobile out from SyncStation after winswup has deleted Your flash... All You need to don is flashing that fphone one more time with some of flasers or use Your backUp... if You have |
03-05-2003, 23:26 | #4 (permalink) | |
Member: 12214 Status: Offline Thanks Meter: 0 | Quote:
03-05-2003, 23:28 | #5 (permalink) | |
03-06-2003, 13:32 | #7 (permalink) | |
If you mean Firmary, then I try, but WinSwup say Unknown Flash type.. If you mean full flash, then I try this too ( with Unisiemens) It`s flashing Ok, but then is dead.. If I try map it, Logger write "login to phone", then " writing IMEI" and then freez... | |
03-06-2003, 14:11 | #9 (permalink) |
No Life Poster Join Date: Dec 2002 Location: U.K Age: 35
Member: 18319 Status: Offline Thanks Meter: 0 | i meen then full flash when it stops writing just press stop then do it again if still dont work tyr putting a new eeprom and if still doing it then it might be your conection |
03-06-2003, 14:46 | #11 (permalink) |
Crazy Poster Join Date: Feb 2003 Age: 62
Member: 21869 Status: Offline Thanks Meter: 0 | go to this yahoo group then sign up and you'll get somes overthere. HTH. you need to find a 98se machine to work with it and make sure you'll use 0nly SL45-19_01.flx - full flash image file good luck. |
03-06-2003, 14:50 | #12 (permalink) | |
May be all3/4 software that I use old version, or not cracked yet? | |
03-06-2003, 15:08 | #13 (permalink) |
Member: 21869 Status: Offline Thanks Meter: 0 | all 3/4 sometime only works on a clean Win98 system. well if its not too much for you.. set a small partition on your 1st HDD. with FAT file system then install 98se on that part. i always work on the phone under Win98. |
03-06-2003, 15:55 | #15 (permalink) | |
Because it start "load aplication" and then gove error message that uncorrect flash type....9090... Can I correct flash type? or ignore this check? | |
cant unlock c1150 with unknown flash type. pls see log | monsterpassword | ThunderStorm Box | 3 | 06-05-2007 11:53 |
2100 unknown flash type ( flash id 000000 ) | Byte | Nokia Hardware & Hardware Repair | 5 | 07-31-2004 10:03 |
B1200 Monitor, soft for 320 alcatel. Unknown flash type! Help me, please. | dan_serg | LG | 4 | 07-17-2004 16:30 |
3310 unknown flash type pls help??? | proxy_gsm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2003 20:30 |
Dead SLik.. Unknown flash type. Pls Help | Death_star | Siemens-Benq RingTones and WallPapers | 12 | 03-16-2003 00:30 |
