Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 10-27-2002, 22:31   #1 (permalink)
Member: 5423
Dear low voltage
Dear friends,
Does somebody has expiriance with low voltage on LPT port.
Notice:
On my Celeron 333, when I running MAP Creator -XAP- on the pins 8 and 9 of DB25(LPT) I have a low voltage about 2,9V, that is a reason why on my home PC this maper doesn't work.
On another PC output of LPT port is 4,7V and application works fine.
Please could somebody tell me on which way I can increase voltage on my PC.
I know another motherbord, but is it any possibility use this one and get still 2V.
I used 2 diodes between pin 8,9 to ATMEL pin20.
Problem is in motherboard I know that but please if someone know solution how can I increase voltage to 4,5-5V I will be greatfully to him.
I would like to change something in dongle of MAXIM if possible if no what can I change to get more voltage.
P.S. That is a reason why somebody has problem with Maxim dongle. Problem is not in oscilator, problem is while low voltage on output of LPT port(pin 6,7,8,9) after running the application
Thanks a lot friend if somebody help me.
Old 10-27-2002, 22:49   #2 (permalink)
legija
Guest
Posts: n/a
Member:
Use EXTERNAL power. Old ericsson battery 4.8V. It is the best way to solve this.
Old 10-28-2002, 05:16   #3 (permalink)
Administrator
Winner58's Avatar
Member: 5
or use power from USB Port.
wbr
Winner 58
Problem solved for low voltage vcc mirecle CPF-BOX Ⅱ 12 07-12-2010 09:18
cect p168c not charge,low voltage 2,5v on battery pin solution? nykocam Chinese Models & Cloned Phones 3 03-09-2010 06:56
CPF BOX II VCC Low voltage gilbertz CPF-BOX Ⅱ 5 11-13-2009 14:14
W350i low voltage on power on/off asmanju08 Sony Ericsson Hardware Repair Area 0 10-09-2009 05:51
E710 low voltage charge sheminith Samsung Hardware Repair Area 2 10-05-2005 12:45
Page generated in 0.21469 seconds with 11 queries
