x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
12-27-2002, 14:47 | #1 (permalink) |
Crazy Poster Join Date: Jul 2002 Age: 47
Member: 13739 Status: Offline Thanks Meter: 0 | Display BLANK after Flashing SL45!!! Is there anyone know what software for setting contrast SL45? Problem come after I tried to flashed it. everything fine but not for display. Anyone know what name of software for it (Set Contrast)? and where can i download that software? thanks 4 help! best regards, nickfg Last edited by nickfg; 12-27-2002 at 19:20. |
12-28-2002, 03:18 | #2 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | What sw did you flashed into your phone? Did you tried to flash with other sw versions? If it´s 49, maybe you´ll need to change it. |
01-02-2003, 11:59 | #4 (permalink) |
Insane Poster Join Date: Jan 2003 Location: vietnam Age: 42
Member: 19398 Status: Offline Thanks Meter: 0 | Hi Do you check what version before you upgrade , try use winswup with chineese language, for example 66882108.exe, or 66885208.exe with java support, may be it can help you. After that you must map it with Inimap.exe, load factory setting for the phone. |
01-03-2003, 18:23 | #7 (permalink) |
Member: 13739 Status: Offline Thanks Meter: 0 | thanks for everyone who helped me to give solution about my problem. I've got my solution for this. the problem only at flexible LCD, it's only dirty between connector with flexible. i tried to opened this mobile and clean all dust around connector. it's about s.t.u.p.i.d answer maybe ) but this is the real truly solution!! thanks, nickfg |
1112 display blank after few seconds need help | /\/\A/\/| | Nokia Hardware & Hardware Repair | 9 | 10-12-2010 13:10 |
error after flash P900 need help ! | ales6orah | Cruiser Suite | 6 | 08-14-2010 22:11 |
X-100 display blank after flash | bluffmaster | UST Pro II | 1 | 06-16-2007 09:18 |
Dead V3 after flashing, really need help | soudies | Smart-Clip | 7 | 05-06-2006 09:18 |
SE S710 dead after flash I need help...! | joallo | HWK | 0 | 09-26-2005 06:51 |
