x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-06-2003, 15:41 | #1 (permalink) |
Freak Poster Join Date: May 2003 Location: Tehran Age: 52
Member: 27936 Status: Offline Thanks Meter: 0 | EEPROM from fubu |
06-10-2003, 08:40 | #2 (permalink) |
Junior Member Join Date: Apr 2003 Location: Bkk,Thailand Age: 46
Member: 26497 Status: Offline Thanks Meter: 0 | Yes ,size of eeprom is 64KB If you have never use siemens battery tool to modified your phone ,you can help me. Can you tell me values of your EEPROM at address offset "0xfb24" about 9bytes? |
06-10-2003, 10:52 | #3 (permalink) | |
Member: 27936 Status: Offline Thanks Meter: 0 | Quote:
IN MY BACKUP IS: 005fb240h: B8 07 77 00 54 04 77 00 96 04 77 00 26 05 77 00 | |
06-10-2003, 15:35 | #4 (permalink) |
Freak Poster Join Date: Apr 2003 Location: the Netherlands
Member: 26889 Status: Offline Thanks Meter: 1 | I have a new battery (1100 mA) but can't find any sensor tool files for it. it always says that the battery is totally full but in about 2 minutes (after i used it some hours) the battery is complete empty and the phone turns itself off. I don't have any experience with sensortool or kind. does somebody want to help me to solve this horrible problem? thnx in advance |
06-11-2003, 00:30 | #5 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | IMPORTANT : *) EEPROM area contents is very dynamic. Its always changed when the phone goes OFF (using normal RED button long-pressed). If you want to test, just compare your own EEPROM block (0x5F0000 size 0x10000) using this method : download EEPROM, save it as EEP_01.bin, turn the phone ON, do something for a while, turn the phone OFF, download EEPROM, save it as EEP_02.bin ... compare those EEP_01.bin file with EEP_02.bin and see the result ... *) We can not just ask or compare the values using static address. *) The easiest way to copy from one EEPROM to another is using Skylord's Siemens_EEPROM_Tools (use EEPROM Block ID) ... RizaPN |
3330 fubu or EEPROM from 0550000 address | clayer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-04-2005 10:59 |
Need advices to how to write eeprom fromMC60 FUBu???!!! | asdv | E-Gold Based Phones | 6 | 07-05-2005 11:32 |
Read Notes from fubu? | beshko | x1x to x45/x50 | 3 | 06-13-2004 08:30 |
how to extract lp from fubu? | gsm2k2 | E-Gold Based Phones | 3 | 04-23-2004 18:57 |
It's possible to put flash+cobba+eeprom from 5.24 to 5.29 (Nokia 5110) | Saulys | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-22-2000 08:24 |
