Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004 Location: Tallaght, Dublin Age: 34
Member: 100436 Status: Offline Thanks: 257
| Fujitsu Siemens T830 unlock ? Sorry if wrong Siemens section Any solution to unlock this phone? BR's Patrick http://www.expansys.com/p.aspx?i=130765 |
| | #2 (permalink) | |
| Moderator ![]() Join Date: Dec 2006
Member: 416908 Status: Offline Thanks: 3
| Quote:
-Try to press the enter button (the lowest right button) for a longer time, this should unlock your device. -Do you have FSC Keylock enabled? (Start / Settings / System / Buttons / FSC Keylock (tab). If so, disable this help. -Do you enable PIN code in your sim card? If yes, maybe you could disable PIN code in other phone and put it back to try. -T830 is for GSM(2G)/UMTS(3G) service. What is type of your SIM? -Turn out the phone has a geographical lock, presumably only functions with UK Sim cards Br, dagos | |
| | #3 (permalink) |
| Just bought the FS T830 from ebay and when inserting SIM [vodafone] it gives message "Warning. New SIM detected. please input phone code or change SIM card". The code needs to be between 4-8 numbers [ie no letters or symbols]. I have tried it with vodafone, t-mobile and o2 sims and get same message each time. I do not know if this code is a network unlocking code or a 'user pin' from the previous owner [awaiting response from him] but would really appreciate your help. |
| The Following 2 Users Say Thank You to Patrick For This Useful Post: |
| | #4 (permalink) | |
| Quote:
Br, dagos | |
| | #6 (permalink) |
| Junior Member Join Date: Aug 2007 Location: Norway
Member: 559566 Status: Offline Thanks: 0
| Hello! Sorry to bother you, but I found your problem her. I have a Fujitsu Siemens Pocket Loox T830 and have got a new SIM card. I have changed it before but then it was ok. Now it demands a "Phone code". I have searched the internet and found you, trying to solve the problem. Can You give me a hint so I can be "back in business”? Thank you so much! Johnny Spernes Norway E-mail: johnny.spernes@online.no |
| | #7 (permalink) |
| Junior Member Join Date: Oct 2007
Member: 617758 Status: Offline Thanks: 0
| Hi, I too have a problem with the phone code of T830. The guy who sold me the device doesn't remember the code, the Siemens Help Center gave me the original Code, but with no result because it was changed and the previous owner doesn' remember it! I hace seen that some of you had the same problem in the past, how did you find a solution? Thank You. vericol from Florence/Italy |
| | #8 (permalink) |
| Junior Member Join Date: Dec 2007
Member: 642881 Status: Offline Thanks: 0
| hi, there is the same problem with my T830, please if you can, help me minnoat@gmail.com |
| | #9 (permalink) |
Member: 654861 Status: Offline Thanks: 0
| Did anybody tried a "factory reset"? Turn off the phone, remove the back cover and next to the red battery holder there is a white reset button. Press that while the phone is being turned on until you see a menu >> select "Factory reset" - let the phone re-boot and check if that solved your problem. Good luck! |
| | #15 (permalink) | |
| Junior Member Join Date: Jan 2009
Member: 942462 Status: Offline Sonork: BKR Thanks: 1
| Quote:
New SIM Detected Please Input Phone Code or Change SIM Card | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| how to Fujitsu Siemens T830 unlock | turkcellgsm | HTC & Smartphones ( WM Without Touch) | 2 | 01-22-2010 19:02 |
| Fujitsu Siemens Pocket LOOX T830 Unlock code need | DemnZ | Phone Unlocking Codes & Maps | 0 | 09-08-2009 16:59 |
| Fujitsu Siemens pocket loox T830 | moji_baba | Siemens Hardware Repair Area | 3 | 06-24-2008 09:07 |
| Fujitsu Siemens T830 unlock ? | Patrick | JAFWM | 0 | 05-02-2007 00:15 |
| fujitsu siemens boot passwd ? | *MaTeOoSh* | Off Topic Zone | 3 | 01-13-2004 07:45 |
