x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-01-2003, 22:54 | #1 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Romania Age: 39
Member: 23520 Status: Offline Thanks Meter: 0 | Help Needed |
06-02-2003, 14:10 | #3 (permalink) |
Member: 23520 Status: Offline Thanks Meter: 0 | Well no I didn't make a backup I never thought Iwill damage my phone. I never beleaved when I first bought my phone the local dealer warned me that SL45 has a lot of software problems. But for now I need the ORIGINAL values from a brand new phone, a phone that never had a fw update or something like that a "virgine" phone. |
06-02-2003, 16:10 | #4 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Latvia, Riga Age: 46
Member: 20879 Status: Offline Thanks Meter: 0 | Sorry I can not help You... I can Tell You more then You like to hear... Every mobiles parameter in EEProm is DIFFERENT!!! It is about signal retranslator and Battery parameters, I mean That There are Special calibrating method in Siemens Centers... So the original settings is Uniqe, and it Fits best for YOUR phone only.. |
06-02-2003, 22:05 | #5 (permalink) |
Member: 23520 Status: Offline Thanks Meter: 0 | U mean That I have to go to a SIEMENS service center, and no matter what I do I will not make the phone work in good conditions whith my batter. OK thank's for lettin' me know that. And th think I was about to sell my phone because I thought It was a harware fault. Thx a lot. By the way does anybody have a used SL45(-i) case whith all the component's in it? (mmc contact, battery contact, sim contact, mycrophone, sim latch and vibration motor) I realy need one because my original is destroied and I am using a no name case. I would have bought one but it's to expensive here in Romania it's about 50$ + t.v.a. (taxes) and the avarege salary is 100-150$. If somebody has one please send me an e-mail and I will give U my adress and U will send it ramburs meaning I will pay for the shipping taxes and the value of the package. Thank's in advance for reading this.... my email adress is [email protected] |
06-02-2003, 22:33 | #6 (permalink) |
Member: 20879 Status: Offline Thanks Meter: 0 | Nobody gonna tell You must sell You phone Your phone works fine with non-original EEProm, it is no reason to sell it Simply I just let you know that Your phone works better with Your original EEProm... By the way, who knows, maybe Your new EEProm fits better to You phone than original.. |
06-03-2003, 00:51 | #9 (permalink) |
Member: 23520 Status: Offline Thanks Meter: 0 | To DjCook if U solved your problem please let me know how send me an e-mail or something (i hope it's not so complicated I do not have knolwage in electronics) To GMX@cool If U have a solution for s45 let us know about it maybe it works on sl45 who knows |
06-03-2003, 15:45 | #11 (permalink) |
Member: 20879 Status: Offline Thanks Meter: 0 | @ m2myo As I understand, You have You own EEProm, with fu**ed battery parameters.. Am I right?? If So, please don`t write any other EEp, I mail You what You gonna do, when I come home, now I`m at work, and I do not have Time to write this process.. Good luck for Ya.. |
06-03-2003, 21:41 | #13 (permalink) |
Member: 20879 Status: Offline Thanks Meter: 0 | My e-mail ALWAYS is under my posts So, After I flashed my phone to FW 56, I get trobles with my battery.. Problems was: 1. Some times my phone turned off after full charging.. 2. My phone ALWAYS turned off when battery indicator shows half battery.. It means that my phone works normaly about 1 day, I was thinked that my batt is dead, but I take one from my friend, and was same problem.. I was did following steps to repair: 1. Completly charge my battery. 2. Read *.LOG file from my phone - Use zSiemens 0.96 for this 2.Calcuate map for FW54 - I Use InitMap 1.29 or allSiemens don`t remember... Here is my map, If someone like use it, copy it to *txt document write YOU ID, delete all my comments, save it, rename to *.map and write it to phone with zSiemens 0.96 ******************** Section ******************** ***************** ID: ++++++++ ****************** -Where You see " +" symbol must be written Your ID from You LOG file ********** Old IMEI = 350666-51-++++++ ********** ********** New IMEI = 350666-51-++++++ ********** ************************************************* IMEI Block 00 0x64 0x9A 0xBD 0x52 0xB6 0x18 0x9A 0x81 0x07 0x5E IMEI Block 01 0xB0 0x2F 0xC2 0xCA 0x09 0x59 0x48 0xAD 0x13 0x22 IMEI Block 02 0xF3 0x0C 0x6C 0xDA 0x4F 0x60 0xCB 0xD4 0x72 0xD2 0x89 0xCF 0x62 0xE4 0xE4 0x31 0x5E 0x16 0xD7 0x63 0x53 0x46 0xDE 0x99 0xB2 0x83 0xE8 0x6A 0x17 0x6B 0x16 0x4F 0x78 0x88 0xE8 0x1B 0x00 0x00 0x00 0x00 0xEC 0x36 0x61 0xE6 0x99 0x93 0x26 0x45 0xC7 0x7D 0x0F 0x80 0xBF 0xA4 0x77 0x73 0x68 0xD3 0x4A 0xEC 0xCD 0xD5 0x80 0xB1 0x2C 0x76 0xA4 0x1B 0x13 0xB7 0xAB 0xA2 0x6F 0x07 0x23 0xA0 0x0F 0x72 0xB9 0x68 0xBD 0xDA 0x9C 0xC2 0x58 0x8D 0x9D 0x26 0x44 0x0A 0x45 0xD5 0x0E 0xA0 0xD7 0x00 0xCA 0x69 0x81 0xA8 0xDF 0xD3 0x0E 0x6C 0x97 0xD4 0x2E 0x88 0x32 0xC8 0x01 0x39 0xD9 0xFE 0x6F 0x89 0x64 0x1B 0x16 0x87 0xF6 0xC8 0x99 0xCF 0x5E 0xBE 0x15 0xE6 0xA4 0xCE 0x1F 0x01 0x59 0x69 0x30 0x65 0xC7 0x57 0x27 0xD8 0x8C 0x69 0xE8 0x84 0x8C 0x77 0x77 0xF8 0x1B 0x7B 0xA0 0x6C 0x75 0xE7 0xDB 0xBF 0xB2 0xC4 0xE2 0x95 0x0A 0x1A 0x26 0x43 0x53 0xA3 0x74 0xD5 0x49 0x72 0xF9 0x95 0x07 0x8B 0x02 0xCA 0x06 0xCB 0xA4 0x47 0xD0 0x96 0x0C 0xCE 0x9E 0x84 0xCB 0xB0 0x24 0xF6 0xAC 0xFB 0xBE 0xB0 0xD2 0xB3 0xB4 0x20 0x43 0x60 0x9E 0xD7 0x1C 0x8E 0x90 0xA5 0xA6 0xF4 0xCC 0xE6 0xDA 0xE2 0x03 0x31 0x55 0x02 0xD3 0x88 0xD2 0xA6 0xCB 0x6C 0xF9 0x71 IMEI Block 03 0xD4 0x83 0x22 0xB0 0x4F 0x60 0xCB 0xD4 0x57 0xF0 0xF5 0x8C 0x96 0xB3 0x58 0x90 0x01 0x31 0xEC 0x2B 0x33 0xEA 0xA2 0x81 0x9E 0x10 0x6E 0xC9 0x4C 0x1C 0xFA 0x79 0xBC 0x60 0x5C 0x7C 0x1A 0x60 0xE0 0x99 0x9E 0x76 0x8A 0x2D 0xC6 0xDD 0xF8 0x88 0x06 0x4C 0x45 0x5E 0x19 0xB3 0x9C 0x66 0x05 0xC3 0xF7 0x0B 0x35 0x4C 0x70 0xEE 0xD1 0xD1 0x92 0xAF 0x7D 0xD2 0x67 0x89 0x04 0xA6 0xB4 0x0B 0x60 0xA1 0x14 0x1D 0x20 0x41 0xAF 0xED 0x14 0xB1 0xDF 0xEE 0x97 0xFD 0x87 0xC5 0x59 0xA9 0x29 0x16 0x9B 0x5B 0xE9 0x46 0xB9 0xF7 0x1A 0xDA 0x08 0x85 0x80 0xBD 0x8C 0xE2 0xE5 0x67 0x1D 0xE0 0xCA 0x73 0x0A 0x39 0xA7 0xE7 0x28 0x42 0xEA 0x46 0x7A 0x2A 0x7A 0x71 0x62 0x47 0x8C 0x85 0x16 0xF7 0x04 0x96 0xAD 0x47 0xAC 0xD4 0x37 0xAB 0x6F 0x2B 0x16 0x24 0xCE 0xE9 0xEE 0x95 0x8E 0x20 0x22 0x65 0x23 0xE8 0x56 0x3C 0x79 0x29 0x45 0x5B 0x0F 0x6C 0x02 0x1C 0x58 0xD1 0xA3 0xD6 0xB1 0x96 0xCE 0xFB 0xF3 0x50 0x42 0xCB 0xCB 0x84 0x20 0xFB 0x47 0x63 0x42 0xED 0x3D 0x94 0x8D 0xBC 0x9B 0xC2 0x85 0x62 0x67 0xD9 0x53 0x76 0xD6 0xD4 0x97 0xF5 0x26 0x0E 0x12 0x87 0x02 0x30 0x4D 0x1B 0xA4 0xC3 0xC0 0xB6 0xCB 0x65 0x58 0x5D 0x26 0x25 0x9E 0x5D 0xCB 0x5C 0xF4 0x3C 0x9A 0x20 0x7B 0xD5 0x8A 0x0F ************************************************* Write This map back to Your phone... By the way this mapping removes all kind of locking, forgotten passwords etc. Turn Your phone on and enjoy... PS If You use InitMap, and insert FULLMAP, When You turn on Your phone, You wondering what You will see, all parameters goes to defaults, and phone think that You turn it on FIRST time, it`s like "virgin" He shows You teaching lesson how to use it I was realy annoying about it.. Any Questions?? Write here or send it to my mail [email protected] ICQ 478488 Last edited by DjCook; 06-03-2003 at 22:15. |
06-03-2003, 21:41 | #14 (permalink) |
Member: 23520 Status: Offline Thanks Meter: 0 | @zalaros I still don't have the mail as soon as I will have it I will forward'it to U. @DjCook Yes U'r right I have an eeprom in the telephone ( I have other eeprom files the *.blk ones for the sl45 but they don't work). I will wait for your e-mail |
06-03-2003, 22:17 | #15 (permalink) |
Member: 20879 Status: Offline Thanks Meter: 0 | Hey, my mail is [email protected] |
Help, help, help, need pinout chinese phone bt n200 | Hacker84 | Infinity-Box | 1 | 04-26-2009 17:37 |
Need Help Need Help | GSM DOCTOR | FuriousGold | 4 | 05-30-2006 20:57 |
Need help!! Need fullflash from Bf4 Cpx10D_KI229_SI220021 | s.Mobi | BF, BG, TH, BHx Series | 0 | 08-20-2002 18:56 |
Need help need 768 eeprom and flash files | Ari | Old Ericsson Phones & Sony Phones | 0 | 06-14-2002 17:24 |
SL45 Help NEED!!! How can help? | shammy | x1x to x45/x50 | 0 | 04-25-2002 06:52 |
