x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
09-23-2003, 17:36 | #1 (permalink) |
Insane Poster Join Date: Aug 2003 Location: Bangladesh Age: 54
Member: 37811 Status: Offline Thanks Meter: 0 | Help please C35 Battery low Problem. |
09-23-2003, 20:38 | #3 (permalink) |
Insane Poster Join Date: Oct 2001 Location: Delft
Member: 6618 Status: Offline Thanks Meter: 0 | well, i don't think battery tool will help his problem. this is common problem with the C/M 35. I've got a C35 with same problem, treid several things, reflashing it with repair file etc, battery tool. Still my phone has that problem so maybe someone can come with a real solution?? (some has repaired his phone?) |
09-24-2003, 13:41 | #6 (permalink) |
Member: 6618 Status: Offline Thanks Meter: 0 | hello, i'm a little bit a noob in the inside of telephones and electronics. So what is the PF? And change eeprom? do you mean flash new eeprom or do i have to remove the eeprom from my mob? And PA (power amplifier isn't it?) where is that located? Maybe some one got tutorial on it? (with pics etc) For this problems there is no software solution? And should i change both eeprom + pa? And pf?/ (still little bit of a newbie) |
09-25-2003, 06:27 | #7 (permalink) |
Junior Member Join Date: Sep 2003 Location: Russia Age: 48
Member: 38452 Status: Offline Thanks Meter: 0 | First - try to change EEPROM(fill it from another 100%working phone - not need to remove)-then swup and log-map by Ksie Full. This is software solution. |
Help me!!!NOKIA 6070 Battery low problem | ..::MOBILES::.. | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 01-03-2010 01:46 |
1110 battery low problem and battery empty | kashif_khatri | Nokia Digital Core Technology 4 ( DCT-4 ) | 11 | 08-09-2009 14:52 |
ME45 Battery Low Problem | sin_daemon | x1x to x45/x50 | 2 | 12-16-2005 21:14 |
Siemen's C35 battery charging problem | sunnytek | Siemens Hardware Repair Area | 7 | 01-31-2005 18:30 |
c35 Battery empty problem | macdan | x1x to x45/x50 | 7 | 01-04-2005 00:15 |
