x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-09-2003, 19:01 | #2 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Vietnam Age: 57
Member: 13356 Status: Offline Thanks Meter: 2 | -A50 board : remove 01 resistor ( right cpu ) , move down 01 resistor ( left cpu ) . easy to see that if u compare A50 board and c45 board ! -flashing a50 with full c45 flash file ( u can use Unisiemens soft ) . -repair Imei with Maxim 4A44 software or some another Siemens tool ! ( Maxim 4A44 can't not repair if u see ST flash chip ). in that case , u can use New ID write map . Thats all! |
07-08-2003, 09:21 | #3 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Tasmania Age: 55
Member: 21408 Status: Offline Thanks Meter: 0 | Hi deltas, I have try this convertion , but to full flash A50 I need to use the test point. It don't work without him, even if I have moved the resistor. ??? You have any idea were I have wrong ? 10X |
07-30-2003, 13:09 | #4 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Italy
Member: 7301 Status: Offline Thanks Meter: 0 | I've tryed, but it doesn't work Hi, I've tryed this method, changing and removing resistor, flashing A50 with a C45 Fullbackup made with unisiemens, but now I have a DEAD A50 What did I made wrong??? Bye n Thanks -d-brain |
11-18-2003, 16:29 | #7 (permalink) |
No Life Poster Join Date: May 2003 Location: Ru Age: 48
Member: 29155 Status: Offline Thanks Meter: 15 | Re: why!?.... I replased c45 flashes with a50 chips. Flash it with c45 firmware. After that phone didn't ****ch on, but after several hours I can swith it on. Now phone works, but permanently flashing backlight |
How to convert BIN into HEX for QPST | adfree | GSM Programming & Reverse Engineering | 3 | 02-04-2016 06:28 |
how to convert B220B into B220... | prince_arsalan | NSPRO | 2 | 04-30-2009 14:37 |
How to Convert CID50 into CID52 | bukshi_mobile | Cruiser Suite | 4 | 02-23-2008 23:55 |
hOW TO CONVERT SERIL INTO RJ 45 | TolikBolik | Phoenix Black Box | 1 | 08-17-2005 18:42 |
How to convert L1150 into L1100 | realdodo | LG | 0 | 06-28-2005 08:10 |
