x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-08-2002, 20:55 | #1 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Russia, Moscow Age: 51
Member: 2951 Status: Offline Thanks Meter: 4 | How extract *.xbi file from WinSwup In my notebook (Toshiba Satellite 4015) and in Win98SE i can't flash x45 with WinSwup. Can't bootstrap mode. In DOS flash (swupXX.exe *.xbi ) work fine. Need extract *.xbi from WinSwup???.exe 10xs |
06-09-2002, 11:41 | #3 (permalink) | |
Member: 2951 Status: Offline Thanks Meter: 4 | Quote:
óËÏÒÏÓÔÉ ÍÅÎÑÌ. îÁ ÓÔÁÃÉÏÎÁÒÅ ×ÓÅ ÒÁÂÏÔÁÅÔ ÎÏÒÍÁÌØÎÏ. äÏÓÏ×ÙÊ ×ÉÎÓ×ÁÐ ÐÏÄ ×ÉÎÄÏÊ ÔÏÖÅ ÒÁÂÏÔÁÅÔ ÂÅÚ ÐÒÏÂÌÅÍ. | |
06-09-2002, 21:42 | #4 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Moscow Age: 40
Member: 5014 Status: Offline Thanks Meter: 0 | U need to use different Data cable ! Sory for non English text Ïðîñòî îðèãèíàëüíûå êàáåëÿ íå øüþò íå ñ45 íå ìå 45 è.ò.ä.. íàäî êóïèòü íà ðûíêå îáû÷íûé êàáåëü èëè ñäåëàòü ñàìîìó...è âñíå áóäåò ðàáîòàòü .... À îðèãèíàëüíûå êàáåëÿ ïî÷åìó òî íå øüþò ñ ïîìîøüþ Âèíñâàïà è âîîáøå âñþ 45 ñåðèþ |
06-11-2002, 01:04 | #5 (permalink) | |
Power for MAX232 - external +5v, not infernal from COM Port! With autoignition (andromeda scheme). Com Port on Notebook also working..... it is nonsens | |
06-15-2002, 11:08 | #6 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Leon
Member: 8804 Status: Offline Thanks Meter: 4 | i am having the same problem, except for mine goes through flashing, but with no power @the end. I think it has to do with the speed of the COM port under dos, in your case, disable the proccessor's cache (internal) i think it will do the trick, i am not sure it will work after flashing though> |
06-19-2002, 13:14 | #7 (permalink) |
No Life Poster Join Date: Jul 2001 Location: East Europe Age: 54
Member: 5452 Status: Offline Thanks Meter: 1 | Yes Fofodaman is right, I have the same problem with my Omnibook HP800CT, Intel 166 MHz, 32 MB RAM, 98 % soft works but some doesnt. In according to this i rather use desktop mashine with processor >200 Mhz and Win98Se too. Bye. |
06-19-2002, 15:04 | #8 (permalink) |
Member: 8804 Status: Offline Thanks Meter: 4 | & you wanted to save money by upgrading i kept my 486-DX266 untill now true i can not find a controller card, & when you do, it will cost you the same for an Intel P3 proccessor but it helps. anyhow, disabling the internal & external cache should help. |
How to Read Flash file from C975 | shakeelajmal | Smart-Clip | 1 | 01-25-2005 22:06 |
HOw to calculate .rpl file from .ask file. | J-lock | UFS2 + UFS3-Tornadoflasher | 0 | 12-31-2004 11:36 |
How to get flash file from gx10/gx10i | FREETIME | Sharp | 0 | 03-02-2004 19:29 |
Make xbi file from zimens 1.22 bin flash? | Bojan20 | x1x to x45/x50 | 1 | 08-28-2001 08:43 |
How to use xbi files... | timitiz | x1x to x45/x50 | 0 | 07-29-2000 17:32 |
