How to fix s46 "wrong software"? Hi, Can anyone help me with fixing wrong software on s46? The phone started up displaying "wrong software" and then it shut down. I reloaded my original flash file, but the phone still doesnt boot. Now it doesnt even display wrong software anymore. Just shuts down. Any help would be greatly appreciated Thanks Nick |
I think u should Try vth SST program. It's might help u. Regards...!! |
Remove S46 worng software 100% Use SST software and just unlock it your phone will be OK 100% |
sst kills s46 the only solution possible is martech 1 or 2 and i asure you it works i personally killed 4 s46 by unlocking them using sst |
maybe you've used "SST cracked" ? |
I used SST-GSM. Anyway, can someone tell me what is the exact procedure to repair the phone? Thanks |
Regards |
Where can I get a good EEPROM. I dont know if mine is good anymore. Freia says Invalid decoded IMEI, EEPROM IMEI () is corrupt, original IMEI is empty (not locked) Can I use FREIA to load the EEPROM and fix the IMEI? Thanks Nick |
I advice you not to post things that you do not understand or you are not sure.It may cause harm to others. |
No? Then you should not use a software for unsupported models |
Regards |
