Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 04-25-2005, 08:34   #1 (permalink)
Member: 139845
Unhappy How to fix s46 "wrong software"?
Hi,
Can anyone help me with fixing wrong software on s46? The phone started up displaying "wrong software" and then it shut down. I reloaded my original flash file, but the phone still doesnt boot. Now it doesnt even display wrong software anymore. Just shuts down.
Any help would be greatly appreciated
Thanks
Nick
Old 04-25-2005, 13:10   #2 (permalink)
Member: 136103
Originally Posted by malcho
Hi,
Thanks
Nick
Which software u have used to fixing ur problem?
I think u should Try vth SST program.
It's might help u.
Regards...!!
Old 04-25-2005, 13:27   #3 (permalink)
Member: 59720
Remove S46 worng software 100%
Use SST software and just unlock it your phone will be OK 100%
Old 04-25-2005, 14:32   #4 (permalink)
japunlock's Avatar
Member: 87396
sst kills s46 the only solution possible is martech 1 or 2 and i asure you it works i personally killed 4 s46 by unlocking them using sst
Old 04-25-2005, 14:45   #5 (permalink)
SST-GSM's Avatar
Member: 38795
Question
Are you sure?
maybe you've used "SST cracked" ?
Old 04-25-2005, 17:43   #6 (permalink)
Member: 139845
I used SST-GSM. Anyway, can someone tell me what is the exact procedure to repair the phone?
Thanks
Old 04-25-2005, 18:11   #7 (permalink)
Fronius's Avatar
Member: 121698
Thanks
Well, with Martech upload good EEPROM, after this make "IMEI Repair", and phone should be OK. I've fix many dead S45 with this, and S46 is more/less same phone, just assembled for different market. Ofcourse, this can also be a hardware fault. Then this solution doesn't help. Basicly, idea is to upload good EEPROM in phone, fix IMEI, and reflash phone with desired firmware (not necessary, but you can make fullflash also. Fullflash means Bootcore, EEPROM, firmware). Anyway, try and post results.
Regards
Old 04-25-2005, 19:06   #8 (permalink)
Member: 139845
Where can I get a good EEPROM. I dont know if mine is good anymore. Freia says Invalid decoded IMEI, EEPROM IMEI () is corrupt, original IMEI is empty (not locked)
Can I use FREIA to load the EEPROM and fix the IMEI?
Thanks
Nick
Old 04-26-2005, 06:23   #9 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks
If you have used a valid working SST.It is not a problem.The procedure is simple
Old 04-26-2005, 06:28   #10 (permalink)
SST-GSM's Avatar
Member: 38795
Regards
S46 is a totallly different phone from S45.
I advice you not to post things that you do not understand or you are not sure.It may cause harm to others.
Old 04-26-2005, 06:29   #11 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks
Nick
Can you see anyway in frea s46 model?
No?
Then you should not use a software for unsupported models
Old 04-26-2005, 11:37   #12 (permalink)
Fronius's Avatar
Member: 121698
Yea?? And what is differrent? Antenna, design, or what?? When you try repair phone, design doesn't mather, hardware makes the difference. S46, like S45 is OTP empty phone, and phone arhitecture is pretty much same, only difference is operating bands. There exist two versions of S46 PCB, regular, and AT&T. Flashes are a little bit different (flash chips are not same) And don't advice me on something that you don't know!
Old 04-26-2005, 11:40   #13 (permalink)
Fronius's Avatar
Member: 121698
Thanks
Nick
Well, i have two versions of EEPROM, one for AT&T PCB, and one for regular PCB, but i dont know which flash type do you need. And I have only Martech EEPROM. If you need it, I can post you.
Regards
Old 04-26-2005, 11:47   #14 (permalink)
SST-GSM's Avatar
Member: 38795
Please go and read phone specification before posting nonsense!!!
Old 04-26-2005, 12:29   #15 (permalink)
Fronius's Avatar
Member: 121698
Ok, whats the difference? Damnt, man has "wrong software" problem, and he need good EEPROM. Who cares for phone specification!!!! If you want, help him, if you don't, then don't, but don't push yours post counter in this thread!
how to fix 02x2 camer prob. due to flash s4sajii Redbox 5 10-19-2004 14:07
How to unlock s46 ronnyek x1x to x45/x50 5 04-01-2004 16:35
How to unlock S46? navoye x1x to x45/x50 0 04-01-2003 03:25
How to unlock s46 ssatcom x1x to x45/x50 1 02-16-2003 18:02
how to unlock S46 mobileclinic x1x to x45/x50 0 02-09-2003 07:36
Page generated in 0.49277 seconds with 12 queries
