x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
04-26-2005, 18:34 | #16 (permalink) | |
No Life Poster Join Date: Sep 2003
Member: 38795 Status: Offline Thanks Meter: 106 | Quote:
So think THRICE before posting !!! | |
04-26-2005, 22:15 | #17 (permalink) |
Junior Member Join Date: Apr 2005 Location: Los Angeles Age: 49
Member: 139845 Status: Offline Thanks Meter: 0 | Hi Guys, No need to get personal. I appreciate any advice given and at this point I can try anything to get the phone working. I dont care if I completely kill it in the process either. It will be a learning experience. My S46 was locked to ATT originally. I dont have martech software. Is there any other way to upload the flash you could give me? Can i use a cracked version? Thanks N |
04-26-2005, 22:23 | #18 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Boston
Member: 21920 Status: Offline Thanks Meter: 10 | Okay once and for all. S46 IS NOT SIMILAR TO S45. S46 is TDMA and GSM and is a totally different phone. Freia + S46 = DEAD S46 SST (Yes, even cracked), Martech, or Griffin CRD can all unlock S46 OK. The solution to Wrong-Unlocked S46 as S45 is writing a good EEPROM. I know this is available to Martech customers since I use their product. SST... I know you're listening-- I assume you provide it as well. CRD is only for unlock, not repair. Bottom line... Once you have killed S46, you need original Martech or SST. If you don't have it, take the phone to someone who does. |
04-26-2005, 22:27 | #19 (permalink) |
Member: 139845 Status: Offline Thanks Meter: 0 | Ok. The craked sst is what killed the phone on the first place. I guess I will need to find people with the original SST as u suggest and find good EEPROM. But why is the original needed? Does it calculate checksums based on the good EEPROM file which the cracked version dont? Just curious. Appreciate your help N |
04-26-2005, 22:35 | #20 (permalink) |
Member: 21920 Status: Offline Thanks Meter: 10 | A read-out EEPROM is fine too as long as you rewrite the original IMEI afterwards. Basically, when the phone is unlocked as the wrong model, the wrong part of the EEPROM is overwritten with the unlocked data, resulting in missing/corrupted information. You need to make it right again |
04-26-2005, 23:56 | #21 (permalink) |
Member: 139845 Status: Offline Thanks Meter: 0 | I used the cracked SST to unlock it. I also used it to readout the original EEPROM, but I dont know if it did it correctly. It sure didnt repair the phone right... So I may need an original EEPROM. Do you know where I can get one from and if only original softwares can write it? Thanks N |
04-27-2005, 11:19 | #22 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Croatia Age: 42
Member: 121698 Status: Offline Thanks Meter: 0 | Okay, they are not similar, I know that, but "Wrong software" repair solution is same as S45, and most of other siemens phones. Upload good EEPROM, make IMEI repair, enter original IMEI, and that's it. Ofcourse, if is not hardware fault. That's all that I was trying to tell. When phone is dead, TDMA doesn't work anyway! Phone specifications doesn't mather. I apologize for misunderstanding that I was started, and that was my fault that I didn't specified what exactly I mean when I was told that phones are same. Mea culpa! But my solution of this problem wasn't wrong, and I think that nobody is misguided with my post! Once again, sorry. This forum is for helping, and not for discussion who is smarter. No hard feelings, and sorry again. Regards |
04-27-2005, 14:39 | #23 (permalink) | |
Member: 121698 Status: Offline Thanks Meter: 0 | Quote:
Regards | |
04-28-2005, 16:47 | #29 (permalink) | |
Regards | |
how to fix 02x2 camer prob. due to flash | s4sajii | Redbox | 5 | 10-19-2004 14:07 |
How to unlock s46 | ronnyek | x1x to x45/x50 | 5 | 04-01-2004 17:35 |
How to unlock S46? | navoye | x1x to x45/x50 | 0 | 04-01-2003 04:25 |
How to unlock s46 | ssatcom | x1x to x45/x50 | 1 | 02-16-2003 19:02 |
how to unlock S46 | mobileclinic | x1x to x45/x50 | 0 | 02-09-2003 08:36 |
