Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 08-07-2002, 11:13   #1 (permalink)
Member: 14394
Thumbs up How to Repair your dead SL45 / 6688
First, prepare these SW below:
1. All 3/4 2.0.5 crack by XzZ
2. SL45-19_01.flx
3. Logger & Map Maker
4. IMEI Writer
These all files are only work with Windows 98 SE
Get all SW files here:
Teddy GSM
If you have have all those files, then following these instructions bellow:
Before run the program, you must check the cable data, Baud Rate (115kb), and COM port!
1. Run Flasher (aall34 2.0.5_XzZ.exe)
- Load File Flash Image -> SL-19_01.flx.
- Choose 'Phone Type' -> SL45, DO NOT SELECT 6688, eventhough your mobile is 6688.
- Check 'Write Flash', 'Write IMEI', 'Burst Mode'.
- Leave blank IMEI number (000000-00-000000-0).
- Click 'Init Mobile' then push imediatelly your mobile button ON.
- Wait 'til the progress finish (Sending Application, Erase Blocks, Copy Program).
- If you failed in this step, just try again.
2. Run Log Reader (A3X#Part1.exe)
- Select 'Logger' Tab.
- Select 'Model' -> SL45, eventhough your mobile is 6688.
- Click 'Read Phone' then push imediatelly your mobile button ON.
- Wait 'til the progress finish and the Windows IMEI appears.
- Fill the 'New IMEI' with your mobile IMEI w/o last digit (eg. 350017-51-019823)
- Click 'Save Log', save the file into the folder and name it as your desire.
3. Run MAP Maker (A3X#Part2.exe)
- Select 'IMEI Change' Tab.
- Click 'Open Log', then select 'yourfile.log'.
- Click 'Save Map', save the file into the folder and name it as your desire.
4. Run MAP / IMEI Writer (Public4.exe)
- Select 'Write IMEI' Tab.
- Click 'Open Map', then select 'yourfile.map'.
- Click 'Write IMEI' then push imediatelly your mobile button ON.
- Wait 'til the progress done.
5. FINISH, Enjoy your mobile again
Regards,
Teddy Bear
Arek Suroboyo
How to repair your LG u880 Dengel LG 41 10-20-2012 13:55
HOW TO REPAIR A DEAD SHARP GX29 or HOW TO FIND THE BEST FILES OF GX29 ??? Eagle7 Sharp 3 06-02-2008 20:42
** how to got your dead motorla in test mode without force cable ** MR PROTEC P2k Series 13 02-08-2006 23:16
How to Repair your dead SL45 / 6688 ardiw x1x to x45/x50 3 04-16-2003 18:43
Page generated in 0.18496 seconds with 11 queries
