x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
02-15-2004, 13:14 | #2 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Croatia/Zd Age: 43
Member: 26670 Status: Offline Thanks Meter: 5 | download fw56 for sl45i upgrade your sl45 with that version. Connect your sl to pc with data cabel. Your phone must be off and battery must be FULL Start up winswup with fw update (v56) Check pre-check and post check boxes Set up setting (COM port...) Click ok. Shortly click once or couple time "red phne button" (ON/OFF), and be carefull that phone DOESN'T switch on. Now process will start. Wait for 15min, and that is it... Now, you only have to start java activator for v56, do same thing like in upgrading (red button click), and it is over in few sec. Now go to surf/fun option and see is there Java you can download java activator at www.siemensfreaks.com under download/upgrade and fw56 you can download at www.gsm-multifund.de/index2.html |
02-15-2004, 13:21 | #3 (permalink) | |
Junior Member Join Date: Feb 2004 Age: 36
Member: 54010 Status: Offline Thanks Meter: 0 | Quote:
Thank you very much !!! | |
02-15-2004, 14:01 | #4 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Romania Age: 39
Member: 23520 Status: Offline Thanks Meter: 0 | U forgot to mention thah if he want's the battery indicator to still work he has so save the original blk settings, i don't remember how but he can search the forum for that. good luck |
Can someone tell me how to activate java for Siemens SL 45 ! | Adidasss | Java, iOS, Android, Symbian development | 1 | 02-19-2004 04:07 |
need help in upgrading a sl 42 to a sl 45i | sl42_2_sl45i | x1x to x45/x50 | 2 | 06-28-2003 09:10 |
how to unlock siemens sl 45 version 3 and version 00.7 | =GsMnL1-TeAm= | x1x to x45/x50 | 0 | 12-11-2001 21:26 |
How to disassemble Siemens SL-45? | du | Siemens Hardware Repair Area | 1 | 07-12-2001 15:17 |
How to disassemble Siemens SL-45? | du | x1x to x45/x50 | 0 | 06-22-2001 17:43 |
