x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-11-2003, 13:00 | #1 (permalink) |
Junior Member Join Date: Jun 2003 Age: 42
Member: 31170 Status: Offline Thanks Meter: 0 | LED's Thanks |
06-12-2003, 00:00 | #3 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Banana Republic of Germany Age: 55
Member: 7769 Status: Offline Thanks Meter: 0 | everything depends on the leds c45 - no problem, use leds with a high mcd - around 50 and up is good - short the resistors and everithing is fine wihe the a55 u must use good leds with a low power consumption - i used aome asia imports - the are working with old motorolas and newer siemens model but i dont know if they will be available on mars ;-) |
06-12-2003, 14:00 | #6 (permalink) |
Member: 7769 Status: Offline Thanks Meter: 0 | the voltage for the leds is to low, if you have a little fun with the resistors, you have almost 3,5 v - (normally around 2,9v) blue, white, truegreen and some pink leds need more than 3v to be bright enough but you can change the leds - test ist and if they are to dark for you - short them (or change them) |
New Nokia 6310 with BLUE LED's for sale>> | logosunlimited | Main Sales Section | 0 | 02-10-2002 00:31 |
3310 troubles with LED's??? | GsMen | Nokia Hardware & Hardware Repair | 4 | 01-11-2002 01:14 |
Led's on M2bus | vasoide | Hardware Equipments for GSM | 3 | 12-26-2001 12:03 |
Blue LED's | xbox | Main Sales Section | 12 | 10-08-2001 04:57 |
Hyper Blue LED's | Daz | Main Sales Section | 3 | 08-01-2001 18:49 |
