x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
06-08-2002, 12:02 | #1 (permalink) |
Junior Member Join Date: May 2002 Location: UAE Age: 52
Member: 12404 Status: Offline Thanks Meter: 0 | ME45 EEPROM data damaged here's the log.. LOG File. Version: 4.00 This log file should be sent to GsmHacking.com ************************************************** ****** [Model: Siemens Me45][PhoneID: 5C6CBFD5][Desired IMEI: 350172-52-228805] Thanx in advance regards Girish.. |
06-09-2002, 02:21 | #4 (permalink) |
Member: 12404 Status: Offline Thanks Meter: 0 | Thanx Dreamgsm and Gomel for responding.. but could you explain how to write epps from 1f0000 with 010000 ?? I'm just an ametuer in this.. please help...thanx in advance.. regards Girish |
06-09-2002, 02:30 | #5 (permalink) |
Crazy Poster Join Date: May 2002 Location: poland Age: 43
Member: 11793 Status: Offline Thanks Meter: 0 | there is somewhere a whole thread about it...look for it... ive got that solution saved to the file..so...(its just copied from that thread): ------------------------------------------------------------------------ 1. Take any working map-file for LC Uploader, for ex. SL45_45BD75D1.lc for SL45 or CSME45_2BDA1FCA.lc for C45. 2. Now edit this file in hexeditor: 0008-000B - change 4 bytes to PhoneID your phone (0009-000C in ldb-file). 3. Start *_lcu.exe, select an option "Write Def. EEP", load corrected *.lc and press Init Mobile. Default eeprom it is written in the phone! 4. Now it is necessary to write the working map in the phone with Siemens IMEI Writer. ------------------------------------------------------------------------ mail me for tools... Last edited by gomel; 06-09-2002 at 02:38. |
06-09-2002, 02:57 | #7 (permalink) |
Member: 12404 Status: Offline Thanks Meter: 0 | Thanx gomel.. i still don't know how to edit a .lc file.. where can i get an editor for it???.. and the phone ID, is it the one which comes in the log file? eg:- mine was showing PhoneID: 5C6CBFD5 .. and which 4 bytes do I have to change? and one more doubt.. where can I get this *_lcu.exe?.. I know I'm bugging u a bit more than what I shoul... but please help if u can... Thanx regards Girish |
06-09-2002, 03:20 | #10 (permalink) |
Member: 12404 Status: Offline Thanks Meter: 0 | Thanx for the response in GSM-Forum.. Now I got a .lc file from someone and I loaded it in my phone.. but it shows an error message "EEPROM damaged use x45_GetUp_App." what doest this mean?? phone is still not working... just a "birrrrr" when I try to switch it on.. please help.. regards Girish |
eeprom data damaged | marici24 | x1x to x45/x50 | 10 | 06-17-2002 21:02 |
SL42e EEPROM data damaged | KATOUE | x1x to x45/x50 | 9 | 06-07-2002 05:53 |
S40 EEPROM data damaged | Jebek | x1x to x45/x50 | 7 | 05-28-2002 06:25 |
what is the solution for EEPROM data damaged | Sher | x1x to x45/x50 | 6 | 03-24-2002 07:48 |
eeprom data damaged? What can i do? | Proggy | x1x to x45/x50 | 6 | 01-16-2002 14:39 |
