me45 is it worth upgrading fw? Hi guys,I recently bought a siemens me45 it comes with firmware v24,is it worth buying a cable and upgrading to fw v30? Anyone knows the differences? |
So, my oppinion is to don't invest money to upgrade your phone (is too old) and if upgrade process is stopped, damage your phone :rolleyes: dagos |
When upgrading the firmware do I have to unlock the mobile? |
dagos |
Only more 2 questions,if I mod the original me45 cable will it serve to update firmware on a m35? What is a PA on a m35? Because I have an m35 with battery problems,and after searching here I know that they can be software fault or hardware (pa) fault,I wanna fix it, the phone is almost new. |
Siemens ME45 and M35 use the same (serial) data cable. See on http://pinouts.ru/CellularPhones-P-W...5_pinout.shtml . PA is the Power Amplifier ( IC PF08112B) and is located on the RF part. Which battery problem you have? dagos |
I used siemens sensor tools and it seems ok now,I must test it further. I am going to mod my original me45 cable,are there any noticeable changes from fw12 on m35i? |
-first, your battery map is wrong (phone stop charging on the lower value of the voltage). -second, you have the hardware problem in your phone (too much power consumption in stand-by mode). Regarding to the fw diferences on C/M35 phones, I don't know, because this phones is too oldies and not have more facility (comparing to the E-gold phones - for example). Don't loose your time to repair verry old phones... dagos |
When I have the cable donne I'll post my doubts :D Thanks one more time |
I've upgraded my me45 to v30,I am quite satisfied I did it,the phone is a little faster. Is there a way to put portuguese on these phone? |
