Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 05-12-2001, 20:58   #1 (permalink)
Member: 109
Red face need flashfiles until this evening ! pl. help me !
Hi my friends !
I have 2 C35, one V15 and one V16. Unlocking did not worked for me with standard software as you described.
So I will try to unlock both with V12 unlocker and flash them down to software version 12. that should work, but I have no flashers (original siemens).
please help me very fast, cause both must work correctly this evening.
ahmm. the V16 phone was unlocked by x3u file but than told me security code is set and won't take any code from me to enter.
please send me the flashers or a solution incl. progz which will work for me.
I am not a lamer. I unlocked over 500 diffrent phones in the last 2 years.
computer deffinitivly works correct. It works fine with other phones.
my email is [email protected]
THANK YOU VERY VERY MUCH !
Squesch
Old 05-12-2001, 22:04   #2 (permalink)
fox
Member: 4489
Thanks Meter: 2
try with siemens x35 service tools 1,7 by martech.
you can find it in this Forum,
good luck
Fox
Old 05-13-2001, 00:09   #3 (permalink)
Member: 109
Post
found it.... "Where do you wanna crash today ???" - Virus inside !
started with virus inside but phone couldn't connect.
than I tried using the flash method in windows and pure dos mode. both couldn't connect to the phones.
my cable works ! unlocked many siemens x25 with it.
or must I modify my cable for that new x35 phones ? if yes, what do I have to change ?
thankx
Squesch
Old 05-13-2001, 09:50   #4 (permalink)
Member: 4460
Post
Hi!
You don't have to make any modifications to your cable. Just keep trying to flash it with original flash for Siemens (Swup+XBI file). Run it in DOS, not just windows dos prompt. You'll get this screen:
SIEMENS AG SWUP SoftWareUpdateProgram V1.93 Jan 3 2001 , 13:01
Ini-FILE: .\SWUP.INI
software-update under Windows on your own risk !!!
Could not contact the mobile, shall I try the software-update nevertheless?
Attention ! No liability!
are you sure ? (y/n) y
Software from 09.02.01 at 11:24:53 will be updated
tested: 100%
tracecable with V4!
trying to connect to mobile with EGold-Boot-Strap-Loader
error connecting mobile with egold!
But don't worry. Just run it again and again and it will work. Maybe you'll have to try it about 30 times, but don't give up! IT WILL WORK!
You may run Swup vith /nocheck to skip waiting when Swup is trying to find your phone.
Good Luck, [mikee]
Old 05-13-2001, 13:13   #5 (permalink)
Member: 109
Post
Thats correct. I got that error message. I will try it now.
Thanks for your help. I will report it to you if it works.
Squesch
Old 05-13-2001, 22:36   #6 (permalink)
Member: 109
Problem solved, phones are working.
I made a treeible miss ! I forgot to plug in the external power of my cable . After that flashing works.
Thanks for your help !
Bye Squesch
Pl help me for this file supporter rk_grover77 SpiderMan 7 01-07-2010 20:13
need to flash samsung i607 pl help me ruvanw1979 Samsung Flashers, Software, Firmware. 2 11-14-2009 09:15
need kifung s108 tx rx pl help me ruvanw1979 Infinity-Box 6 01-05-2009 22:14
wiza 200 need upgrade pl help me ruvanw1979 HTC & PDA WM( With Touchscreen) 7 07-08-2008 10:59
pl help lg 275 lock problem pl help me ruvanw1979 Infinity-Box 3 11-06-2007 13:12
Page generated in 0.35714 seconds with 8 queries
