x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
12-19-2002, 22:23 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | need help with dead C25 v10 i tried to flash with different versions : 07,10,12 (exe files) but ot result, phone dont power up many times i tried all.exe program , it ends ok ,on display service mode but again no power up C25 totalFlasher doesnt work on my PII 366 in win even dos modes i tried Koci software in "flash image" mode with v51.c2r file - no result, with v46.bin i got "invalid procedure call or argument" at the end of flashing maybe i need v10.c2r or 05.c2r flashes?? please help!! br |
12-21-2002, 21:36 | #2 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 44
Member: 6772 Status: Offline Thanks Meter: 17 | To SVH : You can't use (10000000000000%%%%%%%%%%) update soft for yor v10 upper that xx (04,06,07,10,11,14). Try to revive your phobne: Start flasher 61xx (I mean any LP). Wait until flasher has erased youre phone's sw, then disconnect phone from interface or just remove battary. After that flash any sw and lp you want but below or equal 14. Versions below 4x,5x,61 are downgradable. If you are shure that version was 10 than your phone 100% revivable. I hope it will help you. PS: If you have any problems then contact me [email protected] Regards |
12-22-2002, 10:32 | #4 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Czech Republic
Member: 1993 Status: Offline Thanks Meter: 94 | Flash it with FULLFLASH (include eeprom) - sw by Koci - than repair imei with ALL25 and that unlock it with andromeda (Network/Userlock) to get network....100pro solution... |
12-22-2002, 11:03 | #5 (permalink) |
Member deceased !! Join Date: May 1999 Location: Wien/Austria Age: 65
Member: 5 Status: Offline Thanks Meter: 1,884 | Hi your phone is not C25power. So you can`t upgrade higher than 14. flash it with any file lower or = 14. after that start all25 and go in "TESTMODE" |
12-27-2002, 02:21 | #11 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | thanx i tried your program: Connect phone off Service Mode (i push shortly PowerOn) - OK after Writing Data to Eeprom. No response from Phone! any ideas?? br |
12-27-2002, 22:43 | #12 (permalink) |
Member: 6772 Status: Offline Thanks Meter: 17 | That full flash and flasher that I have sent you are 1000% working! I've backed it up from a working phone! After full flashing you will have 100% working and 100% locked phone. But it should start! May be you have hardware problem? Phone should work after full flashing. Full flashing means MCU,PPM,EEPROM (Sorry for a Nokia style). Contact me on ICQ:52808497 Regards |
12-27-2002, 23:17 | #13 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | @boba ...your account returns mails... i tried your flasher with including flash ..wait for ignition... press On ...sending boot... and nothing ((( all swup flashers ( exe or swup+xbi) work only till v12 if i try to flash by any higher version program dont reacts on press Power or indicate 115k connect, but my phone is v10 so it can connects only 57600 i tried all on: notebook compaq PII-366 W98 and PC PIII-733 W98-Millenium SO: i can do only 2 things- a) flash phone by version till ver.12 b) put phone in service mode by all25 software nothing more i tried to rehot flash and processor - no result phone still dont power on, no light, no any sound... does it mean than something in phone is broken? or do i something wrong? b.r. p.s. boba i havent installed ICQ on my PC now, maybe i do it tomorrow...anyway thanx |
12-27-2002, 23:40 | #14 (permalink) |
Member: 6772 Status: Offline Thanks Meter: 17 | @SVH Sverel things: Windows ME does not support "DOS!!!!!" mode. Only patches are exists. Siemens flashers need pure dos to work for shure. So use pure dos. Go to any friend with win98 installed and the press Start->Control Panel->Add or Remove Programs then press StartUp disk Tab and press create disk. You will have working bootable floppy disk. Use it to run flasher. The C25TotallyFlasher I have tested with almos all OSs and it works on WIN95,WIN98,WINME,WIN2k,WINXP, and it doesn't work under Wine on Linux with kernel 2.4.2-2. I havn't tryed to start it under Lin4Win but I'm shure that it will fail. C25 is 1000% revivable phone. PS: About my e-mail: You must be mistyped. My nik is Be Zero Be Ay. May be you typed O insted of Zero "0" in my name. Regards |
need help with dead c330 | xver | Motorola P2k | 1 | 12-22-2004 01:58 |
Please calc this map for me. I need help with dead phone! | Leslie_B. | Phone Unlocking Codes & Maps | 1 | 04-11-2003 18:23 |
Please help with dead C25 v10 | djanib | x1x to x45/x50 | 4 | 02-24-2003 13:00 |
I need help with dead A3x | Permonik | x1x to x45/x50 | 9 | 01-28-2002 17:58 |
i need help with dead alcatel db 16b 2 Mg | Bolo | Alcatel & TCL Old Models | 0 | 04-22-2000 19:45 |
