Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 10-29-2007, 03:47   #1 (permalink)
Member: 619675
Unhappy network problems with c45 in Iowa...unlocked phone
joined this forum to see if community can help me out like alot of other Internet forums have saved me from troubles
Here's the stumble I have.
I received an unlocked (verified unlocked) Siemens c45 that is compatible with GSM networks like my local carrier, and I have a SIM card set up for my local network. When I powered up the phone on manual network setting, it says it is looking for my local wireless carrier on the screen, but it won't register..............
........anybody have an idea why I cannot connect? the GSM bands are the same as the phone uses......
Old 10-29-2007, 04:50   #2 (permalink)
Moderator
dagos's Avatar
Member: 416908
Hi,
try to unlock your phone using unlock software like "Siemens Unlock v5.1 by Nutzo" or Freia. I suggest to use the Freia software. Search on this forum.
Br,
dagos
Old 10-29-2007, 14:43   #3 (permalink)
Member: 547102
Originally Posted by dagos View Post
Hi,
Br,
dagos
YES!! Do like Mr dagos solution. 100% workly
Old 10-29-2007, 21:55   #4 (permalink)
Member: 619675
Well, I have tried the one piece of software and it refuses to connect to the phone, although other software I have can read it just fine ....... I can't remember if I have tried the Nutzo 5.1, but if it is like all the other unlockers I have tried, I will probably get the "invalid data" error.........but I will try it..........this phone should be unlocked though
Old 10-29-2007, 21:56   #5 (permalink)
Member: 619675
Freia is the one that won't connect
Old 10-30-2007, 05:15   #6 (permalink)
Moderator
dagos's Avatar
Member: 416908
..of course "won't connect", used data cable to unlock your phone. Manny unlocking software give the error if you try to connect with the data cable.
Use ksie5.1 (Siemens Unlock v5.1 by Nutzo).
Select type of phone (C45).
Phone must be off and conected to cable.
Press unlock and then press shortly "Power on" of the phone.
Your phone will be unlocked.
If you want to use Freia, you need to change your cable.
Use DCA500 cable for unlocking with Freia. See on attachemment.
Br,
dagos
Old 10-30-2007, 08:02   #7 (permalink)
Member: 619675
im starting to wonder if there isn't something wrong with this phone.....i did what you said and it appeared to work but I get an error that the IMEI 's are bad and it closes the port.................anybody know if the S45 or S46 is like the C45??
Old 10-30-2007, 09:25   #8 (permalink)
Member: 10679
C45 is DEFINITELY European, won't work in the US.
S46 is for USA.
Old 10-30-2007, 19:14   #9 (permalink)
Moderator
dagos's Avatar
Member: 416908
S46 is for USA.
...correct.
@C45_Iowa: You are from USA ???
Tis question is because C45 phones working on GSM 900 / GSM 1800 Mhz (European fregvency). USA working on GSM 900 / GSM 1900 Mhz.
Br,
dagos
Old 08-27-2008, 07:48   #10 (permalink)
Member: 847241
Mobiles
Hi,
This is Jones.Now a days for every minute one new model phone is been launched by different companies in different parts of the world.In this process Siemens are also launching brand new model phones which are more attracted by people so I hope they will keep this kind of reputation for the upcoming years too
Jones9985
for information Alcohol Addiction...
Iowa Alcohol Addiction Treatment
Old 08-27-2008, 13:52   #11 (permalink)
Moderator
dagos's Avatar
Member: 416908
Originally Posted by jones9985 View Post
Hi,
Jones9985
...this is the joke or what???
Administrators, please erase this post.
dagos
FEEDBACK - If You Have Network Problems With Lg phones,Momodesign, Sagem Gobi TORNADO - SIM 27 04-18-2008 12:52
If You Have Network Problems With Lg phones,Momodesign, Sagem Gobi TORNADO - SIM 2 03-29-2008 22:22
may be a problem with myx5, but after unlock phone unable to make call ashvin Redbox 2 07-24-2005 04:33
Problem with C45 - reception problem TONYTONY Siemens Hardware Repair Area 0 08-11-2003 14:47
Page generated in 0.41009 seconds with 11 queries
