x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
05-24-2002, 17:52 | #1 (permalink) |
Major Poster Join Date: Apr 2002 Location: Indonesia Age: 46
Member: 11444 Status: Offline Thanks Meter: 0 | (NEW) Simple Solution Repair X35 Phone Dead (Tested 100% Work) VERSION 2 For ALL people always asking and searching about this topic, This is a solution i use for repair and your all must know how to use (PLS LEARN by ur SELF) 1. USE MARTECH 1.7 TO WRITE FULL FLASH (CHOOSE X35 FULL FLASHER (X35 VER 05) TO WRITE (THIS FULL FLASHER YOU CAN DOWNLOAD FROM LANDY PAGE)). UNTIL FINISH --> NEXT 2. FLASH YOUR PHONE WITH WINSWUP and USE X35 VER 0503 --> NEXT 3. USE ZIEMENS SOFTWARE 1.22 BY PRO AND PRESS "CEE_REPAIR" (THIS JUST TRY REPAIR ANY DAMAGE BY FLASHER (REPAIR "SERVICES MODE") REMEMBER YOUR PHONE STILL DEAD) --> NEXT 3. TRY YOUR PHONE WITH MARTECH 1.7 FOR SURE IF YOUR PHONE CAN CONNECT TO "SERVICES MODE" (THE WORDs UP ON PHONE SCREEN) --> NEXT 4. IF OK FOR "SERVICES MODE" USE X35EE_UPLOADER AND USE RM0503.BIN (S35) or CM0503.BIN (C/M35) TO REPAIR YOUR PHONE EEPROM. (SOMETIME U MUST PRESS THE "ON" POWER REPEAT 3-5 TIMES UNTIL THE "SERVICES MODE" UP ON THE PHONE) --> NEXT 5. USE ZIEMENS 1.22 AGAIN TO REPAIR CLICK "CEE_REPAIR", NOW YOU GET WORKING PHONE AGAIN --> NEXT 4. USE IMEI CHANGER BY LEAD TO CHANGE IMEI BACK. --> NEXT 5. FINALLY U CAN USE X35 ANY FIRMWARE TO UPGRADE BUT YOU JUST CAN UP TO VERSION 21. CAUSE LEAD IMEI WRITER JUST SUPPORT UP TO VERSION 21 (AFTER VER21 YOUR PHONE WILL ERROR, PLEASE REPEAT PROCEDURE TO REPAIR) THIS SOLUTION TESTED ON S35i AND M35I (WORKS 100%) ALL SOFTWARE YOU CAN DOWNLOAD FROM LANDY PAGE OR ANY GSM SITE. |
06-28-2002, 17:44 | #3 (permalink) |
Crazy Poster Join Date: May 2002 Location: Amsterdam Age: 64
Member: 12471 Status: Offline Thanks Meter: 0 | Martech once killed my phone too. Nothing worked, no 100% (or 1000%) repair method whatsoever. As a last resort I used a reader I had found, and asked someone to calculate a .LC map for me. I flashed it back to my phone with the uploader that came with it, but this failed as well. Then I used the option of the uploader 'Write Default EEPROM', and my phone was alive once more! The programs you need (the reader and uploader) can be found here: http://bontek.terramail.pl. Just find somebody to send the log file to (.LDB), and they will send you an .LC. Flash it back with the option I mentioned above, and your phone might work again. Good luck. |
06-28-2002, 17:48 | #4 (permalink) |
Member: 12471 Status: Offline Thanks Meter: 0 | Hm, the address of the site was mangled when I posted my reply... It was http://bontek.terramail.pl., but it should have been [url]http://bontek.terramail.pl[url]. Note the extra '.' (period). Sorry about that. |
06-28-2002, 17:49 | #5 (permalink) |
Member: 12471 Status: Offline Thanks Meter: 0 | Aargh! Still not right! This should do the trick: http://bontek.terramail.pl. Otherwise just cut and paste the address. |
06-28-2002, 19:17 | #6 (permalink) |
Crazy Poster Join Date: May 1999 Location: Cluj-Napoca, RO
Member: 18 Status: Offline Thanks Meter: 0 | read this thread http://forum.gsmhosting.com/vbb/show...threadid=46499 and ask somebody a flx file for S35, maybe will work. BR Black |
07-18-2002, 14:09 | #10 (permalink) |
Major Poster Join Date: Jul 2002 Location: Middle Europe Age: 54
Member: 13820 Status: Offline Thanks Meter: 0 | HI Why didnt you try Henrich's map creator for x35s with support 24fw. (with solution by Nutzo.) It should be working and easies and cleanest way is mapping. If not work try enemy's solution with x35 repair. Here they are: Henrich 1.2 Enemy's x35 Bye. |
07-18-2002, 14:12 | #11 (permalink) |
Major Poster Join Date: Jun 2002 Location: Germany
Member: 13266 Status: Offline Thanks Meter: 0 | Look for my Solution, tested on 5 death C 35 it works 100%!!!!! Here: http://forum.gsmhosting.com/vbb/show...threadid=49140 Good Luck!! |
07-18-2002, 15:38 | #12 (permalink) |
Insane Poster Join Date: Oct 2001 Location: Sofia,Bulgaria Age: 53
Member: 6959 Status: Offline Thanks Meter: 0 | Many thanks for Your help,my problem is solved few days ago.I repair flash with x35 by Enemy and restore phone with InitService.EEPROM was serious damaged by Martech and only Siemens program solved problem.Maybe this is private case and this solution work 100% for another,but for me-not. WBR |
(NEW) Simple Solution Repair X35 Phone Dead (Tested 100% Work) VERSION 2 | rinvend | x1x to x45/x50 | 21 | 07-28-2020 08:41 |
Simple Solution Repair X35 Phone Dead (Rate if Work) | rinvend | x1x to x45/x50 | 7 | 05-18-2002 09:40 |
