x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
05-24-2002, 18:01 | #1 (permalink) |
Major Poster Join Date: Apr 2002 Location: Indonesia Age: 45
Member: 11444 Status: Offline Thanks Meter: 0 | (NEW) Simple Solution Repair X35 Phone Dead (Tested 100% Work) VERSION 2 For ALL people always asking and searching about this topic, This is a solution i use for repair and your all must know how to use (PLS LEARN by ur SELF). This solution i get while try to downgrade ver24 to ver21. (Ver24 cannot change imei if u change with lead your phone get error and u must use workshop 1.22 pro to repair) 1. USE MARTECH 1.7 TO WRITE FULL FLASH (CHOOSE X35 FULL FLASHER (X35 VER 05) TO WRITE (THIS FULL FLASHER YOU CAN DOWNLOAD FROM LANDY PAGE)). UNTIL FINISH --> NEXT 2. FLASH YOUR PHONE WITH WINSWUP and USE X35 VER 0503 --> NEXT 3. USE ZIEMENS SOFTWARE 1.22 BY PRO AND PRESS "CEE_REPAIR" (THIS JUST TRY REPAIR ANY DAMAGE BY FLASHER (REPAIR "SERVICES MODE") REMEMBER YOUR PHONE STILL DEAD) --> NEXT 3. TRY YOUR PHONE WITH MARTECH 1.7 FOR SURE IF YOUR PHONE CAN CONNECT TO "SERVICES MODE" (THE WORDs UP ON PHONE SCREEN) --> NEXT 4. IF OK FOR "SERVICES MODE" USE X35EE_UPLOADER AND USE THIS EEPROM S/M/C 35 TO REPAIR YOUR PHONE EEPROM. (SOMETIME U MUST PRESS THE "ON" POWER REPEAT 3-5 TIMES UNTIL THE "SERVICES MODE" UP ON THE PHONE) --> NEXT 5. USE ZIEMENS 1.22 AGAIN TO REPAIR CLICK "CEE_REPAIR", NOW YOU GET WORKING PHONE AGAIN --> NEXT 4. USE IMEI CHANGER BY LEAD TO CHANGE IMEI BACK. --> NEXT 5. FINALLY U CAN USE X35 ANY FIRMWARE TO UPGRADE BUT YOU JUST CAN UP TO VERSION 21. CAUSE LEAD IMEI WRITER JUST SUPPORT UP TO VERSION 21 (AFTER VER21 YOUR PHONE WILL ERROR, PLEASE REPEAT PROCEDURE TO REPAIR) THIS SOLUTION TESTED ON S35i AND M35I (WORKS 100%) ALL SOFTWARE YOU CAN DOWNLOAD FROM LANDY PAGE For EEprom u can download from here Last edited by rinvend; 06-12-2002 at 10:51. |
05-27-2002, 08:56 | #5 (permalink) | |
Member: 11444 Status: Offline Thanks Meter: 0 | Quote:
On Landy page this solution similar but many people not really understand. so i make this solution i get while try to repair x35 dead phone and i explain this solution very easy step to use | |
06-11-2002, 05:17 | #6 (permalink) | |
Freak Poster Join Date: Apr 2001 Location: Hungary
Member: 3969 Status: Offline Thanks Meter: 9 | Quote:
THanxx. | |
06-11-2002, 10:10 | #8 (permalink) | |
Member: 11444 Status: Offline Thanks Meter: 0 | hmm Quote:
Pls download full flash on landy page | |
06-12-2002, 06:20 | #10 (permalink) |
Insane Poster Join Date: May 2002 Location: Netherlands Age: 41
Member: 11803 Status: Offline Thanks Meter: 0 | (NEW) Simple Solution Repair X35 Phone Dead Hello rivend, I can't find "CM0503.BIN" (C/M35) TO REPAIR MY PHONE EEPROM. Landy Page changed password ! If you have It, I would be very happy, if you would send it to me (size 64KB) Hope I can bring my M35i back to life. (I can't get this "X35EE_UPLOADER" working under WIN98SE) I read your "SOLUTION FOR REPAIR DEAD X35 PHONE" Thanks alot, Greetz Trailer. Last edited by Trailer; 06-12-2002 at 06:30. |
06-12-2002, 09:43 | #11 (permalink) | |
Member: 11444 Status: Offline Thanks Meter: 0 | Re: (NEW) Simple Solution Repair X35 Phone Dead Quote:
login: mobile pass: elibom X35EE_UPLOADER is working Good on win 98/me (I use this system) Problem for X35EE_UPLOADER is your EEprom phone is Damage. So X35EE_UPLOADER cant boot on your phone. for eeprom ur ask please read my solution for link to download on landy page is Full flasher not eeprom. For procedure on my solution is work if u can using it and have all program, softwaren and understand how to use procedure. | |
(NEW) Simple Solution Repair X35 Phone Dead (Tested 100% Work) VERSION 2 | rinvend | x1x to x45/x50 | 11 | 07-18-2002 15:38 |
Simple Solution Repair X35 Phone Dead (Rate if Work) | rinvend | x1x to x45/x50 | 7 | 05-18-2002 09:40 |
