Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 08-03-2001, 15:32   #1 (permalink)
Member: 4903
Post No network found after unlocking
Hello people<br />i have unlocked a siemens c25 v.49 (SP lock)<br />and after i power on the phone is ok but does<br />not find any network.<br />What could be the problem?<br />Thanks in advance,
Dimitris
Old 08-03-2001, 15:58   #2 (permalink)
Member: 3075
Thanks Meter: 2
Cool
You need find the flash with your lang. pack:
4901-02-03-04-05,.....
The only diference is the language pack used in every packet.
Old 08-03-2001, 16:02   #3 (permalink)
Member: 3075
Thanks Meter: 2
Cool
Any networkż?.... then try to update firmware with swup program to fw53.
You can downgrade first to fw05 just to test the phone.
Regards.
Old 08-03-2001, 16:26   #4 (permalink)
Eerchant's Avatar
Member: 1993
Thanks Meter: 94
Red face
landy!!! <br />what you write here?? all is stupid and good for destroying his Phone....all you need is use Bartek 1.92 and function Repair - or just try to pust unlock button again....or use free andromeda 6.1....do not flash your phone or change language....
Regards Eerchant
P.S. For landy: change lng pack not solve anything and if you upgrade ANY version of C25 Power (fw version 43-53 - power versions (08-12 was not power versions)) to 53 (exept 53 but this is not upgrade) phone will be death.....as with downgrade...you see somewhere 05 firmware for C25....? and if yes it is not compatibile cause to version 12 C25 has other hardware inside.....if you realy do not know ... please do not talk.... <img src="mad.gif" border="0">
Old 08-03-2001, 16:34   #5 (permalink)
Member: 3075
Thanks Meter: 2
Cool
OK Eerchant, but in my first reply i was thinking that all he want is change language.
After reply again with the way to fix, he can downgrade c25 to 05, by the way he always can use c25 Total flasher and restore c25 perfectly.
Regards landy
Old 08-03-2001, 17:24   #6 (permalink)
Eerchant's Avatar
Member: 1993
Thanks Meter: 94
yes landy with C25 total flash - true...c25 POWER (version 43-53 are like CDRW <img src="smile.gif" border="0"> ) but c25 not power not work with total flasher.
<br />Best Regards Eerchant
Old 08-03-2001, 18:20   #7 (permalink)
asas's Avatar
Member: 5198
Thanks Meter: 2
Cool
your IMEI is blocked.
Old 08-03-2001, 20:58   #8 (permalink)
Member: 3075
Thanks Meter: 2
Post
OK, thanks Eerchant.
Old 08-06-2001, 14:28   #9 (permalink)
Member: 4903
Post
Hi guys!<br />The problem stil remains.<br />I used Bartek 192 repair function but<br />the phone can't find any network.<br />I want to flash the phone to a newer version<br />but i am not sure if that will really work.<br />I don't want to make any more damage to this phone. Please if you have any tested working solution advice me.
Thanks
Dimitris
Old 08-06-2001, 15:20   #10 (permalink)
Member: 3438
Post
I had this problem too, I have no step by step guide but I solved this problem when I used different software, for example Bartek 1.92 and if there was still problem than I try Andromeda, or I destruct firmware (Destroyed by C25 Unlocker) and than again try Bartek 1.92. Sometimes I try this 30 minutes, but all times I repair this bug!!!
Old 08-06-2001, 17:26   #11 (permalink)
Member: 4903
Post
The problem is fixed now guys.<br />I flashed a firmware version of v49<br />and the phone finds the network now.<br />The problem is that i lost the language packet <br />with the greek language and i am looking now for a program to read from another phone the language packet and upload it to this one.
Thanks again to all of you.
Dimitris
k550i no network coverage after unlock with furious hightechsquare FuriousGold 4 04-24-2008 20:14
Help, N70 no network coverage after unlock elgar HWK 5 09-20-2007 13:16
Help 6681 No Network Found After Water Damage sandeepmtc Nokia Base Band 5 ( BB-5 ) 0 07-09-2007 18:39
w810 no network coverage after unlock jinto123 Cruiser Suite 8 10-17-2006 12:06
LG C3300 No Network Signal after unlock jamsou LG 2 05-22-2006 12:57
Page generated in 0.19453 seconds with 9 queries
