Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 06-06-2002, 00:44   #1 (permalink)
Member: 8612
Unhappy Problem S45
At inclusion of the telephone the illumination lights up and the sound signal is distributed
I have written down in telephone MAP a file and the problem was not permitted(solved)
That I can still make
Old 06-06-2002, 02:37   #2 (permalink)
Member: 11314
Hi mate !
Don't worry, if it turns on, beeps, and turns off, it's just that you have put a wrong map in there, or you used a program that modified the phone information..
But there is an easy solution !
You take a map logger, version 3.00, or higher, or something that looks like that,
Then you make a log of your phone,
and then you post a request to the "log request" section of this forum.
Normally, in one day you'll have a response
And then, the only thing you have to do is log the new map on your phone !
Isn't that great ?
Well, lots of luck man !
Greetings.
Old 06-06-2002, 02:41   #3 (permalink)
Member: 11314
Talking What about a small help ?
Hi mate !
Isn't that great ?
Greetings.
Old 06-06-2002, 02:44   #4 (permalink)
Member: 11314
Stupid server.. Doesn't really work properly.. What an idea to display twice my message...
Doesn't matter, at least nobody will miss it
Good day to all !
Old 06-06-2002, 02:55   #5 (permalink)
Member: 8612
I did not write down bad MAP a file
The telephone has died at inclusion
Old 06-06-2002, 06:51   #6 (permalink)
DREAMGSM's Avatar
Member: 3377
i think you can solve the pb writing the first one epprom of both s45 has. Worked in two phones with the same problem.
regards.
S45 v21 vs. S45 v30 vs. S45i v04 -V-O-Y-A-G-E-R- x1x to x45/x50 0 06-27-2003 15:57
Update S45 to S45 with slovenian language??? Gsm Trade x1x to x45/x50 0 12-02-2002 21:00
I need s45 eeprom or s45 full backup asas x1x to x45/x50 1 11-05-2002 11:57
S45-> S45i or XTNDConnect PC with S45 undercover_danc x1x to x45/x50 0 07-12-2002 17:40
Problems with S45 enric666 x1x to x45/x50 0 03-25-2002 13:03
Page generated in 0.18469 seconds with 9 queries
