Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 04-12-2002, 15:21   #1 (permalink)
Member: 5452
s35 killed after downgrading...help please
Ii had in my phone s35_2103 flash without slovak language.
I just want to downgrade phone because i hadn't slovak language in it. I tried solution by Landy:
1. fullflash with Martech 05
2. fullflash by swuping
3. repair by Ziemens 1.22
and nothing.
My phone writes me:
Battery is empty, please recharge......or something like this, and switch off.
Please help me.
Old 04-12-2002, 16:04   #2 (permalink)
Member: 7760
Try make map file. It can help you
Old 04-12-2002, 16:06   #3 (permalink)
BufferMess's Avatar
Member: 9856
Hi
You have corrupted eeprom
1. Don`t believe in solutions like full flash with bin, then swap
flash, then workshop repair. Most of the times this solution
does not work. I have tested several times...
2. You should flash the phone with the same version. As far as I
know there is slovak pack but don`t know where to download!
Good Luck
BufferMess
Old 04-12-2002, 17:39   #4 (permalink)
Member: 5452
really need map file...i hope
Is there good person who can calculate map file for my dead s35?
Thanx in advice very much.
log file is:
[Model: Siemens S35][PhoneID: 4F96C699][Desired IMEI: 449197-51-948945]
(last number didn't want to write in, it was 7, i think.)
After re-flaashing my backup with Ziemens 1.22 everithing was gone correctly but EEPROM not (Abnormal termination), so i think so, my EEPROM is down, so i need help so much.
I f i will get a map file, can i use the same siemens logger with write it to my phone?
(You see, I'm really beginner with repairing of phone)
Old 04-13-2002, 01:44   #5 (permalink)
cole's Avatar
Member: 2254
Mail me or post your mail.
Old 04-15-2002, 08:07   #6 (permalink)
Member: 6877
Map calculated from log will not help... because it does not touch EEPROM field with battery data.You can try to find "Sensor tool" also known as "Siemens tool" written by "DarkBear".It's what you want:this program allows to play with battery calibration parameters,etc...
(Search posts for description how to use this program properly)
Old 04-15-2002, 08:38   #7 (permalink)
cale's Avatar
Member: 10742
hello
yes..its true..onli solutions for bateri empty is sensor tool..no map ..its doesn't work
Old 04-15-2002, 13:20   #8 (permalink)
Member: 5452
Smile Problem solved
Thanx for all your replies, guys,
and solution?
1. reflash with martech 05 (EEPROm + ....)
2. flash with 0504 (swupping) - phone still answers: Battery is empty .....
3. reflash with 1804 (with Slovak lp) - still the same
4. repair EEPROM with Ziemens 1.22 and repair with flash_out inside it (it doesn't matter it is suit for c35), but check only EEPROM from 4 choicies!!! - phone alive!!!, but locked to 232 00,
5. unlocking with Mr. Zee
6. Finish
Old 04-18-2002, 14:02   #9 (permalink)
mujie's Avatar
Member: 8304
EASY,EASY..........just use "Cee Repair"
Old 04-19-2002, 14:57   #10 (permalink)
Member: 7995
Thumbs up it's easy man
first
flash your phone with x35_17 by Martech (cracked by gregor )
write full falsh with repair.bin by landy
afterthat your phone will dead - so dont worry
Second
go to landy site, how to revive dead phone by x35_17.
Viola, your phone will be normally again
I had test several phone, couse downgrade. No signal, or Battery Empty ( because eeprom error )
with martech your phone will all erase include your eeprom
good luck and don't forget to pray it
N95 killed after downgrade using mt-box patric Nokia Base Band 5 ( BB-5 ) 15 07-08-2008 23:53
2310 contact service after downgrade !help ! crown Nokia Digital Core Technology 4 ( DCT-4 ) 19 11-27-2007 07:29
NEC E313 dead after downgrade... HELP!!! MaDMaN666 NEC 25 04-01-2006 14:55
a50 v92 dead after downgrade tov4 please map!!! infogsm Phone Unlocking Codes & Maps 1 03-08-2003 02:00
S35 dead after downgrade (v20 to v18)... dimka x1x to x45/x50 2 03-02-2002 00:15
Page generated in 0.49467 seconds with 11 queries
