Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: May 2006
Member: 269306 Status: Offline Thanks: 19
| I have a great problem with 3 siemens a50 phones , with any software i have tested i get boot not accepted without testpoint , with testpoint the phone does not power up while the software asks me to power on . PLEASE tell me what to do about it. Thanks in advance. |
| | #3 (permalink) |
| well i could really use a sugestion on what track to cut , because on a50 all testpoint schematics indicate grounding of a pad next to button 1 on the keypad... P.S. the phone is detected by joker and freia but only without testpoint and i get " boot is not accepted " error. |
| | #5 (permalink) | |
| Quote:
I'm still awaiting a valid solution as i have tried all the programs in all ways and nothing( my serial cable is working fine because i have flashed an Siemens A60 with it). | |
| | #6 (permalink) | |
| Moderator ![]() Join Date: Dec 2006
Member: 416908 Status: Offline Thanks: 3
| Quote:
Siemens A60 have other connector type (and other pinouts). Maybe you maked cable with X50 and X55 connectors (I'm working with this one). Try to modify your cable and insert autoignition option (not need to push shortly the "power on" button). See on attachemment. Br, dagos Last edited by dagos; 06-15-2008 at 15:42. | |
| | #7 (permalink) |
| Yes , i have converted the a60 cable for the a50 connector and i have made proper connections as shown in your pictures. i have also made the autoignition connection but i have placed a 2.2 kohm resistor in series with the diode and it's not working because i still have to start the phones manually. Do you think it's safe to remove the resistor? I have measured and it has around 4v at the autoignition pin with the resistor( the cable i'm using draws power from DTR and other pins of the serial port, maybe it's afecting the autoignition? ). Thanks for the pictures. |
| | #8 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2002
Member: 10679 Status: Offline Thanks: 9
| A50 doesn't need TP, it has the bootcore bug that allows conneting without TP. Just select "bootcore bug" in the Freia setup. You don't need autoignition, you can remove it. |
| | #9 (permalink) | |
| Quote:
Freia , Joker , SST , a50 by jordik , ksie2 etc. they are all failing to send the boot to the phone and i get "boot not accepted" from all of them. Please provide a valid solution to the a50 problem i am experiencing. Maybe a different cable setup? | |
| | #11 (permalink) | |
| Quote:
Like i said i used Freia all versions and they all say "boot is not accepted", i used all boot options. Please post here your version of Freia , perhaps it will work for me. | |
| | #12 (permalink) | |
| Quote:
| | #13 (permalink) | |
| Quote:
unlocked two A50's , and with another soft DirectCOM and Joker , i am trying to repair another A50 whitch is dead (buzz and brief turn on and off). :> ![]() Thanks for your support. | |
| | #14 (permalink) |
| Junior Member Join Date: Dec 2007
Member: 641958 Status: Offline Thanks: 0
| push Delete instances with joker, but you will lost all your photos and sounds but i think you can put them back with gsm control.(I did this for a simens A75 with same buzz probleme and with no test point needed) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Siemens A50 menu key problem | zullu2004 | x1x to x45/x50 | 1 | 07-04-2005 09:45 |
| testpoint SIEMENS A50 V11 | eerfaan | x1x to x45/x50 | 6 | 06-19-2004 13:38 |
| siemens A50 ver 12 problems | tekkelinc | x1x to x45/x50 | 2 | 05-24-2004 19:05 |
| Siemens A50 Problem | mkm | x1x to x45/x50 | 1 | 03-16-2004 11:16 |
| Siemens A50 - audio problem | cooliock2 | Siemens Hardware Repair Area | 2 | 06-01-2003 18:35 |
