Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 12-22-2004, 12:45   #1 (permalink)
Member: 89372
Question Siemens C35i - Battery and Charging Problem
Hi.
I have few mobiles from Siemens C35i (new refurbished), with Li-on Battery and not Ni-MH as the original battery.
I have few Problems, if any1 can help pls:
1) Does any1 know what is the problem that the phones isn't charging even after lots of hours?
2) When i try to charge the phone turn off. what can b the reason?
3) What is the latest Software version of This mobile? where can i get it?
10x,
Ido.
Old 12-22-2004, 18:34   #2 (permalink)
genetic1's Avatar
Member: 70990
1. + 2. It seems that blk (battery) values incorrect by changing Li-Ion-battery. Old battery has assumedly about 600-700mAh...new one about 1200mAh - isn't it?
Sorry, but in that case I can't help you and I don't know, where you get a blk-file for C35i.
What's going on, if you insert old battery???
3. This is a little bit language depended...
Here you can download all versions: (Please check language vers. first!!!)
http://eh.student.utwente.nl/~landy/
user mobile
pass elibom
(For updateing you strictly need a non-orig.-data cable!!!)
That's it - good luck.
genetic1
Old 12-22-2004, 18:38   #3 (permalink)
mohammad2004's Avatar
Member: 71144
test the voltaj output phone
change the cpu sensor by sensor tools
replace the charging ic
Old 12-27-2004, 08:32   #4 (permalink)
Member: 89372
The battery capacity is as the original.
from the info i get till now it seems to b SW problem.
about the site u gave, i d/l from it, but its XBI files. how can i open them? i've been told i need FLS or BIN file. do u know anything about it?
10x.
Old 01-03-2005, 23:12   #5 (permalink)
djirda's Avatar
Member: 95250
Bad quality bateries,or bateries made bad in factory.Often problem.
It can be solved but then you are risking to damage your phone.
Do you think that you can calibrate beter than Siemens itself.
Try to enter engeenier mode and watch the charging voltage when charging phone to see on what voltage it is going to turn off.maybe you will get the idea how to calibrate.
c65 battery and charging gorang Siemens Hardware Repair Area 0 04-22-2007 23:54
T610 battery strange charging problem (+) SFlood Sony Ericsson Hardware Repair Area 12 04-16-2007 17:06
M65 problem :/ insert simcard and charge problems. Gsmhq Siemens Hardware Repair Area 4 03-03-2007 05:42
V300 battery not charging problem !!! facayu@yahoo.co Motorola Hardware Repair Section 1 09-22-2005 18:43
low battery and flash problems? mr-zap Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-01-2001 12:59
Page generated in 0.46922 seconds with 11 queries
