Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 11-05-2002, 05:00   #1 (permalink)
Member: 9891
Siemens FullFlash CRC Check method
Hi,
there are two source could be found in the net (DarkBear's) : siemcrc.cpp and siemcrc4x.cpp, which can be used to check CRC value for CMS35 and SME45.
Is there any news about C45, M50, and other model. I did try to check good flash for C45v14, SL45v52, M50 (unknown version) using those algorithm, but all said CRC in the flash is different with the calculated CRC. Do they use different algorithm, or just the location of CRC word in the full flash is different ?
Thank's,
rizapn
Old 11-05-2002, 07:27   #2 (permalink)
Member: 13092
Can i get these sources?
Thanks
Old 11-05-2002, 08:15   #3 (permalink)
Member: 12263
Thanks
Look your mail
regards
Wind
Old 11-05-2002, 10:16   #4 (permalink)
Crazy Poster
Member: 14048
Re: Siemens FullFlash CRC Check method
Originally posted by rizapn
Hi,
Thank's,
rizapn
Here you are some offsets for C45v35...
Disable the first CRC check (exactly dying after it).
D74F4: 3D CC
D74F5: 0A 00
D7502: 3D CC
D7503: 03 00
Disable the second CRC check.
DBBFE: 2D 0D
Enable NetMonitor.
9FDF6: 2D 0D
Old 11-06-2002, 00:30   #5 (permalink)
Member: 6768
Originally posted by Wind
Look your mail
regards
Wind
Can You send me too because I dont understand why after change any bytes in EEPROM soft calculate another CRC ?
Old 11-06-2002, 00:53   #6 (permalink)
Member: 12263
OK......send it!
Wind
Old 11-06-2002, 15:50   #7 (permalink)
ken
Member: 5472
Please tell us what is the principle to disable CRC check for any version of C45...
Old 11-06-2002, 19:09   #8 (permalink)
Crazy Poster
Member: 15540
Hi,
ACID[mrp] wrote a new program which includes darkbear's crc calculator and the secand crc check
so here it is
http://www.minet.uni-jena.de/~holg/crc_gui_setup.exe
Old 11-07-2002, 17:50   #9 (permalink)
Member: 6768
OK......send it!
Wind
Hi.
Probably I have any trouble with my mailbox because I don't recive this source (siemenscrc.cpp ....).
Can You send me again to kaczor@hot.pl ?
Thx
Old 11-07-2002, 20:43   #10 (permalink)
Member: 12263
Ok.....look your mail again....
Wind
Old 11-08-2002, 08:26   #11 (permalink)
Member: 9891
Hi,
my reason to ask this CRC question is to build a software for full-flash modification (such as ringtone and icons) for any firmware (not only x35 like my previous x35fft).
After some trial, I came to this conclution :
*) the main CRC calculation is : CRC1 = W1 xor W2, and CRC2 = W1 + W2
*) *IF* all Siemens firmware CRC algo is based on that, I think another idea to correct CRC after doing some firmware modification (without knowing the *exact* CRC calculation) is to add some more data (in my trial, 3 word are enough), so : CRC1new xor A xor B xor C = CRC1old, and CRC2new + A + B + C = CRC2old ... (first I try with only A and B, but always impossible to get the right value).
I did try with both siemCRC and siemCRC4x, and this idea is OK. The CRC after modifying some data, plus that ABC data is exactly same with the previous/good ones.
Any suggestion ?
Regards,
rizapn
DEAD GD68 Stoped at CRC CHECK cellquery Panasonic 6 09-16-2006 07:22
C35 - How to remove CRC check? axim x1x to x45/x50 4 07-12-2004 18:11
Disable CRC Check Kunio x1x to x45/x50 1 04-07-2003 21:06
CRC check in BF series osvaldas BF, BG, TH, BHx Series 11 08-03-2002 23:16
Ericsson Tools 2KAY stops during "CRC Checking... Jurik Old Ericsson Phones & Sony Phones 1 05-21-2000 00:27
Page generated in 0.73647 seconds with 11 queries
