Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 10-18-2002, 10:44   #1 (permalink)
Member: 16802
Siemens Sensors Tool 1.1 and ME45 battery problem
Good morning.
I was repairing my phone (Siemens ME45) and now it turns off while charging and it can be charged maximum to 80-85%.
I saw in archive that Siemens Sensors Tools can help me. Below is a screenshot form this program. I don't know what values should i enter before writing them into the phone.
http://www.darim.host.sk/clip.jpg
Can you help me ? Thank you all in advance.
Regards
Darim Hanuk
Old 10-18-2002, 12:44   #2 (permalink)
ken
Member: 5472
Your SpgY03V is very low for Li-ion it should be 72xx or nearly try to adjust for best value of your batt.
Old 10-18-2002, 13:49   #3 (permalink)
Crazy Poster
Member: 9777
Hmmm, i remember i could not make Sensors Tools to work with S45. Would you be so kind and send me this version of application you are using with ME45 ?
You are using standard service cable (without external power supply and auto-ignition), am i right ?
Old 10-18-2002, 19:25   #4 (permalink)
Member: 15820
How long does your battery on ME45 last? My holds for about 3-4 days with no any kind of prevention.
It would be nice if you can really give us link for that software you have using.
And if someone could explain some explanation of how to using this program, it would be very very good.
THANKS.
Old 10-20-2002, 02:49   #5 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
Please send me too.
Or indicate Url to download.
Thanks
Old 10-20-2002, 08:31   #6 (permalink)
ken
Member: 5472
Sorry!!! I think he posted the picture that capture from C45 or Sl45.
Old 10-20-2002, 08:41   #7 (permalink)
Member: 16802
Ken : Thank you. I have changed that value to 7200 and now i can charge my battery to 100% again and the battery keeps as long as before.
Only the one problem remains - the phone is turning off when it is charged fully at 100% (previously it was turning off approx. at 80%)
Here's the url for SST 1.1 :
http://www.darim.host.sk/siemens.sensors.tool_1.1.rar
Regards
Darim Hanuk
Old 10-20-2002, 08:53   #8 (permalink)
Member: 15820
Darim, can you tell me how do you know how much percent your battery is charge? Do you only look at the indicator on display or there is some other more, precission way? Than again HOW MUCH YOUR BATTERY last?
Old 10-20-2002, 09:05   #9 (permalink)
Member: 16802
I can see it with ACCU monitor from Developer Menu.
Old 10-20-2002, 14:34   #10 (permalink)
Member: 12263
Regards
Darim Hanuk
Darim for turning off i think that the value of TBattof must be higher than Spg
Old 10-20-2002, 17:02   #11 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
It gives me errors when i try to unpack Siemens..1.1.rar
Please anyone sent me unpacked, or in zip, but with good crc, please....
Old 10-20-2002, 19:10   #12 (permalink)
Member: 16802
drug_store : need winrar 3.0 for unpacking this file.
Old 10-20-2002, 19:15   #13 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
thatīs the one I use...
but it says wrong end file or something like it
Old 10-20-2002, 19:25   #14 (permalink)
Member: 16802
Hmmm, i adjust :
SpgY03V to 7200
and
TBatOff to 7201
and battery indicator is too low and phone turns off after it's connect to the charger.
Would anyone be so nice and read his S/ME45 with Li-Ion 840mAh using Sensors Tool 1.1 and type all parameters here so i could copy them ?
Thank you in advance.
Old 10-20-2002, 19:30   #15 (permalink)
Member: 16802
Drug : try this one :
http://www.srs.spb.ru/siemens/utilit..._akkum_1.1.rar
How to use Sensor Tool to fine tune SL45 battery sl45vietnam x1x to x45/x50 40 11-23-2004 10:27
Siemens Sensor Tools Help - Battery empty Problem stigma x1x to x45/x50 4 03-15-2003 12:10
Need blk-File for Siemens Sensor Tool for SL45 vikado77 x1x to x45/x50 4 07-09-2002 22:04
Siemens Sensor Tool gamalabel x1x to x45/x50 2 06-24-2002 22:36
Page generated in 0.20698 seconds with 9 queries
