x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
10-20-2002, 19:31 | #16 (permalink) |
Insane Poster Join Date: May 2002
Member: 12263 Status: Offline Thanks Meter: 1 | i use this, downloaded from http://www.o45m.ru/program/wrar300.exe anyway if u have also problem i can send u in zip format |
10-20-2002, 19:44 | #18 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | to darim S45 values 0000 : 3895 0002 : 4189 0004 : 63127 0006 : 1001 0008 : 78 000A : 62473 000C : 106 000E : 65227 0010 : 100 0012 : 0 |
10-20-2002, 20:08 | #20 (permalink) |
Junior Member Join Date: Oct 2002
Member: 16802 Status: Offline Thanks Meter: 0 | drug_store : hmmm, your 0000 is very low. So was its mine before i've changed it to 7200. When my 0000 was abount 3800 the phone couldn't be fully charged. Are you sure your S45 works fine and can be charge at 100% drug ? I guess it should not. |
10-21-2002, 20:50 | #24 (permalink) |
Crazy Poster Join Date: Feb 2002 Location: Poland
Member: 9490 Status: Offline Thanks Meter: 0 | Ladies and Gentlemans! These settings are correct(works fine for me)!Your phone wil not turn off while charging(and battery will be 100%),after ME/S45 to ME/S45i. Block file (blk) with these settings send to me NRG,so I would like to say Thank You to him. Best regadrs. PS:Just put these settings in sensors tool and write phone! 0000:4183 0002:4221 0004:63461 0006:1011 0008:79 000A:62490 000C:106 000E:65233 0010:100 0012:0 |
10-22-2002, 07:33 | #25 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Serbia, Belgrade
Member: 15820 Status: Offline Thanks Meter: 0 | Thanks man, but I don't know should I changde this parametersbecause as you can see they are very close to my original paramters? One more thing. Is it enougt to save original EEP so to if you are not satisfied with your new settings you can just put your old EEP back? |
10-22-2002, 09:12 | #26 (permalink) |
Member: 12263 Status: Offline Thanks Meter: 1 | Save Parameter Eelite block 67 @Dentin U can save and reload your parameter of battery with sensor tool of DarkBear and it isn't necessary saving and reloading all EEprom for this SAVING: click on read phone after click on Write file put a name like "mine" that's all RELOADING: click on read file select a file block u want es. "mine" click on write phone done |
10-22-2002, 11:39 | #27 (permalink) |
Member: 9490 Status: Offline Thanks Meter: 0 | Hi! As Wind said, all settings of battery change in siemens sensors tool. Just put these settings in sensors tool and write your phone(first save blk file of with your settings-just for sure).Thats all. Regards |
10-22-2002, 12:22 | #28 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Holland Age: 61
Member: 11291 Status: Offline Thanks Meter: 0 | Does anybody knows values for c45 with 650mha Li-ion battery? Phone doesn`t turn off or stops charging,but i want to know value to set my c45 with 650 Li-ion to the best setting! Wbr Rossifan |
10-22-2002, 12:34 | #29 (permalink) | |
Member: 12263 Status: Offline Thanks Meter: 1 | Quote:
works fine but in the last day a lot of time after sending sms go off! ...i am not sure that is a problem of battery..... Wind | |
How to use Sensor Tool to fine tune SL45 battery | sl45vietnam | x1x to x45/x50 | 40 | 11-23-2004 10:27 |
Siemens Sensor Tools Help - Battery empty Problem | stigma | x1x to x45/x50 | 4 | 03-15-2003 12:10 |
Need blk-File for Siemens Sensor Tool for SL45 | vikado77 | x1x to x45/x50 | 4 | 07-09-2002 22:04 |
Siemens Sensor Tool | gamalabel | x1x to x45/x50 | 2 | 06-24-2002 22:36 |
