Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > x1x to x45/x50
x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50.
Old 12-14-2002, 22:23   #31 (permalink)
Member: 14004
Thanks Meter: 6
This data is very helpfull !!!
Originally posted by Witek
PS:Just put these settings in sensors tool and write phone!
0000:4183
0002:4221
0004:63461
0006:1011
0008:79
000A:62490
000C:106
000E:65233
0010:100
0012:0
I had one ME45 with data simmilar to yours, but phone kept constantly shutting off when charging completes.
So, i firsrt tried to put 7200 for 0000 and 7201 for 0002, and
chargung error was corected, but phone was allways showing
full battery (even on Vbat 3.3 V !!!)
Then i tried your data, and phone is OK. Charging normal, no shut-off, battery lasts for more than 120 min of talk (battery is one year old!)
Thank you very much!
Old 12-15-2002, 13:31   #32 (permalink)
Member: 18294
It is nice to try different data. But does anyone know, what does each filed exactly mean? And what format are the data which should be written into those fields? There are some voltage and temperature data..... I need some help with this, please. I don't have problems with charging, but I have problem with temperatures. My phone does not turn on when it is cold.
Old 12-21-2002, 07:17   #33 (permalink)
KoTsK's Avatar
Member: 17360
0000:4183
0002:4221
0004:63461
0006:1011
0008:79
000A:62490
000C:106
000E:65233
0010:100
0012:0
it's work!! i'm using me45 with s45i040101 ... thx for Witek
Old 01-18-2003, 04:33   #34 (permalink)
Member: 5971
Thanks Meter: 2
hi there... where did you downloaded the s45i040101? and is it possible to use this flash file to convert my ME45 (3618) to ME45i?
Thanks a lot!
Old 01-31-2003, 07:58   #35 (permalink)
KoTsK's Avatar
Member: 17360
same as WITEK ... but i tried to change value in 000C ...
0000:4183
0002:4221
0004:63461
0006:1011
0008:79
000A:62490
000C:107
000E:65233
0010:100
0012:0
works well, too. tested on ME45i 040101.
Old 05-26-2003, 18:12   #36 (permalink)
CellM@n's Avatar
Member: 3194
Thanks Meter: 41
Can sensor tool repair s45 which only showing indicator Charging for 2 seconds only ???
help plss
Old 05-26-2003, 18:34   #37 (permalink)
Member: 14004
Thanks Meter: 6
Yes, sensor tools could probably help. Try it, but first save your data to file.... If something goes wrong, load your backup to phone. Try values posted in this thjread and inform us of results!
Old 06-25-2003, 11:31   #38 (permalink)
Member: 31918
I've tried the WITEK settings and the phone is working fine?
What are the meaning of each setting? Not only 0000, 0002, 0004, 0006. Is those setting thge perfect tunning for the mobile?
Thanks.
Old 07-16-2003, 09:38   #39 (permalink)
Member: 19926
Ladies and Gentlemans!
These settings are correct(works fine for me)!Your phone wil not turn off while charging(and battery will be 100%),after ME/S45 to ME/S45i.
Block file (blk) with these settings send to me NRG,so I would like to say Thank You to him.
Best regadrs.
0000:4183
0002:4221
0004:63461
0006:1011
0008:79
000A:62490
000C:106
000E:65233
0010:100
0012:0
These settings are working for me too, but there's one problem... The phone can't be fully loaded with carkit. I noticed that with my old settings, the phone loaded better. Now my battery indicator says the phone is fully loaded, much earlier. With my old setting I also couldn't fully load battery so I wonder wich settings I should use.
Somebody any idea to get it loaded better in carkit?
Old 09-02-2003, 19:21   #40 (permalink)
Member: 38224
If anyone got good results for M35i please post... will the values already posted work well for other models like C35/M35?
Is there any risk to the phone by using wrong values not suitable for my phone?
Old 03-03-2005, 11:01   #41 (permalink)
Member: 122576
Do you guys have a working link for those files?
Here is my issue, and maybe you can suggest an alternative solution... but from what I am looking at, I might be able to fix it with this tool you are talking about...
I have an S55... When I start to charge the phone, it discharges. I bought a new battery yesterday and I got the same problem. Bought a new charger too, just in case.
Now I have no technical understanding of the phone, but could you suggest some way to fix this? Thank you.
PS. Now there is no juice in the batteries to switch it on and charge them.
Please answer back, thanks
Old 03-04-2005, 21:05   #42 (permalink)
Member: 122957
Hi all,
I have a similar problem with a MC60. The display always shows me "Battery empty. Please charge.". Does anyone know the right configuration for this mobile?
From Siemens Sensor Tool:
0000: 4740
0002: 4182
0004: 64205
0006: 1007
0008: 97
000A: 65181
000C: 97
000E: 65272
0010: 100
0012: 0
How to use Sensor Tool to fine tune SL45 battery sl45vietnam x1x to x45/x50 40 11-23-2004 09:27
Siemens Sensor Tools Help - Battery empty Problem stigma x1x to x45/x50 4 03-15-2003 11:10
Need blk-File for Siemens Sensor Tool for SL45 vikado77 x1x to x45/x50 4 07-09-2002 22:04
Siemens Sensor Tool gamalabel x1x to x45/x50 2 06-24-2002 22:36
Page generated in 0.38087 seconds with 8 queries
