Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
| | #1 (permalink) |
| Major Poster ![]() ![]() Join Date: Jun 2002 Location: viet nam Age: 36
Member: 13108 Status: Offline Thanks: 0
| sl45 change flash and eeprom damaged Hi all Please help me I have 2 sl45 total dead I had changed flash for 2 phone You know, there are 2 flash inside sl45, one is 4mb 2 is 2mb, I decided to change flash after repaired by hardware when i change the second flash(intel F16C3TA), and reflash by winswup, the phone could not switch on, I use all 345 crack by xxz, loaded sl45v19.flx or even sl45v49.flx, and after flash, "all done"After that I Make log, write map but cannot , it display "EEprom damaged" Use ldb, lc file, load defaul eeprom, but still cannot Use unisiemens with donger emulate still cannot Now, I dont know what to do The phone still eeprom damaged !!!!! Help help help Thank you very much |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2001 Location: 5.12.14
Member: 6486 Status: Offline Sonork: 100.79846 Thanks: 50
| Hi all Please help me I have 2 sl45 total dead I had changed flash for 2 phone You know, there are 2 flash inside sl45, one is 4mb 2 is 2mb, I decided to change flash after repaired by hardware when i change the second flash(intel F16C3TA), and reflash by winswup, the phone could not switch on, I use all 345 crack by xxz, loaded sl45v19.flx or even sl45v49.flx, and after flash, "all done" After that I Make log, write map but cannot , it display "EEprom damaged" Use ldb, lc file, load defaul eeprom, but still cannot Use unisiemens with donger emulate still cannot Now, I dont know what to do The phone still eeprom damaged !!!!! Help help help Thank you very much --------------------------------------------------------------------------------- buddy --copy a good eprom from a working phone and than write back by unisiemens - now ur phone should say PHONE FAILIURE-- --now calculate the map and upload to phone -- i hope it should work-- best of luck best regards gohar |
| | #3 (permalink) |
| Hi Thank you very much but it cannot solve And I have same problem with 1 c45 and 1 s45 I dont know how to repair I have try in 3 pc Thank in advanced |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks: 0
| Download flash file (Flx19) at my site or at http://www.odblokgsm.home.sk/downld.htm Download All 3/4 2.0.9 Download Siemens Logger 4 (at least) Download Siemens Map Maker 4 Now use All 3/4 2.0.9 to flash your phone. (check "Write Flash" / "Write Imei" / "Burst Mode (10% faster)" boxes.) Tip: Problems flashing??? - Change Baud Rate After you´ve flashed your, use Siemens Logger, and select "Logger", select SL45 on Model list and press "Read Phone". (Press On in your mobile when it says "Scanning...") This it takes 5 seconds When done, press "Save Log", and save it with anyname you want. Now use Siemens Map Maker 4, and select "Open Log", select the log file you´ve created. Now press "Save Map" and save it with anyname you want. Now use Siemens Logger 4, select "Write Imei", select SL45 on Model List. Press "Open Map", and finnaly "Write Imei". This it may takes 10 or 15 seconds. Now your phone should be working again. Now update to any version you want. My advise is to update at least to v52, but if you can and know how, update to v54 with JAVA. (52 also as JAVA). Good Luck |
| | #6 (permalink) |
| Hi Drug_Store Thank very much to your answer But could you please give me a link to Software Siemens Map Maker V4.0 Thank in advanced |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| my sl45 dead.. is this eeprom damage or what? | erwinsie | x1x to x45/x50 | 2 | 06-07-2004 00:57 |
| need a35 and c35 full flash and eeprom | gsmbac | x1x to x45/x50 | 3 | 11-21-2003 16:11 |
| T20 and t28 - writing flash and eeprom ok, but dont power on. | oleg192 | Old Ericsson Phones & Sony Phones | 2 | 06-16-2003 10:44 |
| Flash and EEPROM for A1018s 00W01 and 00W10 | mc1_mc2 | Old Ericsson Phones & Sony Phones | 2 | 06-18-2002 12:51 |
| Neptune K10 flash and eeprom needed. Phone dead after wrong flash. | sat | Mitsubishi | 8 | 01-17-2002 14:50 |
